Hey guys.
Recently just recovering from a cold(thanks rl friends! ) & have been looking at builds, but slowed down due to the ill... Ok, at first I was looking a a 8320 setup, but with budget, birthdays and christmas I've had to look at slight alternatives. I would be gaming at no more than 1080p&with a single gpu. What would you're thoughts be on either setups...
My first build would be...
AMD 6300
M5A97 EVO r.2
Seasonic sII520 (bronze) Or 620 version?
WD blue 1tb
Kingston HyperX DDR3 1600MHz CL9 8GB
Arc Midi v2 Or Corsair 300r
Windows 7 Or 8...
The second I was looking at... was involving FM2+, that included...
Gigabyte a88x sniper FM2+
Althlon x4 760k
Seasonic sII520
WD blue 1tb
Windows
Now, I really need to ask you're opinions on this. I know the 760k is worse than the 6300, but how much worse if playing at 1080p max, with a single gpu?
The reason I was looking at the FM2+ motherboards(&the asus a88x pro/gigabyte up4 when they release) was because of the new features (&motherboards), with amd seeming to be concentrating on the FM2+ socket atm. The plan would have been to get the 760k(£60), then upgrade to a new kaveri/steamroller chip when they release (I would be 90% go with a single gpu without the apu...unless kaveri/apu really kicked ass) The Fm2+ would give me a path to upgrade with the new mobos. Or I could get the 6300, but I'm just unsure with no word on am3+ or Steamroller for the fx chips.
Also, as you probably noticed, I will have to use my old gpu for a few months (Ati 5750) Before I could get say a r 270/80.
Would the athlon perform well with say bf4, when compared to the 6300?
Just with the budget, and probably not upgrading much (unless a good Fm+ cpu/price) released.
Also, and this is making me not know, Windows 7 or 8? I was set on 7, but would 8 be better as once I buy the Os I don't plan on changing it for quite a while(i dislike 8 from seeing it at friends&reviews/youtube etc)
Any way, thanks for reading and any replies!
) & have been looking at builds, but slowed down due to the ill... Ok, at first I was looking a a 8320 setup, but with budget, birthdays and christmas I've had to look at slight alternatives. I would be gaming at no more than 1080p&with a single gpu. What would you're thoughts be on either setups...My first build would be...
AMD 6300
M5A97 EVO r.2
WD blue 1tb
Windows 7 Or 8...
Althlon x4 760k
Seasonic sII520
WD blue 1tb
Windows
		 I was trying for an 8320, but money might not allow it with Christmas/Bdays so soon! So I was mainly torn between the 760k (upgrade to a sr next year), or the 6300.
 Also, the reason I really have to get a new rig sorted is because this pc is slowly dying (currently using on screen keyboard
 Also, the reason I really have to get a new rig sorted is because this pc is slowly dying (currently using on screen keyboard ) I was saving up, but with this happening have to act pretty soonish. Thanks again for you're reply!
 (but with a a88x mobo, and the 760k)
