- 5 Sep 2011
- Surrey
Depends at what price entry. The 290X reference will probably get a small price cut - if not before Christmas, just after.
Based on the totality of our results, I'd say the GeForce GTX 780 Ti has returned the single-GPU performance crown to the green team's trophy case in a controversial split decision. Perhaps more importantly, the GTX 780 Ti achieves these performance levels while running at much lower temperatures and noise levels than the R9 290X.
Cherry picking reviews, hehe.
You can't argue with 8packs results. Although the 290 is already faster than the 780, once it gets off that reference cooler it will pull further clear.
(and then leg it) but I do ask why the 780 was clocked at 1123Mhz? All the 780's I have seen will happily sit at 1200Mhz and over all day long in games.Not cherry picking, this is the 780TI official review thread and no one had posted this one.
Exactly what I was thinking. A 780 @1123MHz Vs a 290 Pro @1220 with a third party cooler?! Apples to oranges. Should've just gone stock vs stock and then max oc vs max oc. Probably done to show off newer cards.
The 290 Pro was on the reference cooler. Confirmed by 8Pack when i asked in that thread.
Agreed but even you can see the very conservative clocks of the 780?
290X stock cooler yes.
The one we used could only manage a 6000MHz memory overclock, which meant the R290 Pro which had a 6400MHz memory overclock was giving more or less same performance as R290X.
The R290 Pro is the real bargain king.
We shall update the results at somepoint in the future with a decent clocking R290X.
So with a better clocking 290X its possible that 780TI might get de-throned.
Its possible but likely only when compared to a standard non overclocked 780ti. I've just read a review where a 780ti can overclock by a huge margin..(mem nearly hits 8000Mhz qdr)
"Maximum overclock of our sample is 1120 MHz GPU (base) clock (28% overclocking) and 1975 MHz memory (13% overclock).
GPU overclocking potential is VERY impressive. It's been a while since I've seen a GPU do almost 30% OC on launch day. Memory overclocks well, too, thanks to the fast memory chips, and reaches typical levels for 7 Gbps GDDR5"
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_780_Ti/30.html
How long did it take you to find these skewed results?![]()
A week later, the 290 is launched and what a launch, it is so good, it makes the 290X look rubbish in comparison. So we have the 290 that is the 7950 bargain of last gen butttttttttttt the 7950 was ~£200 and the 290 is £300, so now it doesn't look so tempting and especially with the rap of the cooler/noise.
Fwiw right now, if I wasn't on water, I'd rather take a 780 with a nice quiet cooler for £400 odd over a ref 290 for £320 odd.
Being on water though, 290+block = price of 780 so I'd take a 290.
/ramblings...
