I think you're right. Supermarket mince does seem to have a lot of sinew minced into it and it appears to be minced to the bare minimum they can get away with and it makes a tough burger. They don't actually specify what cut is used even when they describe it as 'lean steak mince' but I'd suspect it's something like a mix of belly (brisket) and other 'stewing steak' cuts that they otherwise don't sell enough of. Even if you were to mince you're own out of cheap cuts, I suspect you'd do a better job yourself and it would taste better.
I actually go against what is said about about using high fat content mince. I usually use supermarket 'lean steak mince' because it's got a softer texture when cooked than the cheaper ones with the higher fat content. I add quite a lot of salt and squeeze it all together with a small sprinkle of dried white breadcrumbs. The breadcrumbs soak up a lot of juice and stop it coming out the burger when you cook it. Cook it hot and fast to get a bit of char on the outside and don't overcook it or it'll dry out.
D.P.'s suggestion about pressing the patty: I saw an awesome method on DDD - place the patty between two sheets of greaseproof paper and give it a good hard smash with the bottom of a heavy saucepan. It works brilliantly
You reminded me I need to buy a meat mincer.
Just buy DR mince when it's on offer, it makes Taste The Difference/Finest/etc mince taste the same as the value stuff.
DR is epic (apart from the postal spam).
I crumble in half an oxo cube to the mix as well as onion etc
So why "most of the fat will drip out anyway and what is left is nice and healthy"?
I find that adding salt and pepper to the mixture makes them more flavoursome rather than when you're supposed to right before frying.
their prices are just farcical though, not just high but utterly stupid
