calf doms, already...........is this even normal?!
For some reason, my iPad isn't embedding your videos...
iOS 7 by any chance?
Which vid belted or unbelted or both?
Working on having everything being tight with the deadlifts, Lats are on etc. Could be that I wasnt pulled back enough before having everything tight and starting the pull.
Yes to iOS7. Best way to ruin an decent iPad.
Both, tbh - more clear in the belted, weirdly. Part of me wonders if the problem is that the weight isn't heavy enough, meaning you're slacking off because you're strong enough... whereas if you went in with something unpleasant, you'd tighten up a lot more?
