Catzilla 1.0 Benchmark Scores
Reference 780Ti
1094 Core / 3499 Mem (Stock with 106% Power Target basically):
1234 Core / 3649 Mem (OC with 106% power Target)
How does one do 1080p without upgrading software? Custom 1080p Preset and leave what it sets?
Reference 780Ti
Unfortunately you can only run @576p and 720p unless you upgrade the software.
I have put your CPU down as a 2600k @4.4 I got this from another thread.
And congrats on a very nice score.:)
Ah, that's a shame. Rarely see > 50-60% GPU usage in 576p :D
2600k @ 4.4 indeed. Used to run at 4.6 but BF4 does not like it. Catzilla really likes CPU speed as well, good to see a combined benching suite.
What crashes were you getting in BF4 with the cpu at 4.6? BSOD's?
Hi Kaaps, here's my catzilla runs below i7 930:4.2ghz / GPU - Boost:1060mhz / memory:6958mhz -
576p
720p
Cheers,
Oldphart.:)
Hi kaaps, l take it my results don't make sense, yes l'm running sli and its set up correctly in Nvidia Control Panel > Configure Sli is set to Maximise 3D performance=Ticked + PhysX setting=CPU.
Both Gpu'S are working with Boost, at stock both idle at 915mhz when Max Boost comes in GPU 1=1058MHz / GPU 2=1084MHz. The only thing l can think of when looking at Catzilla Benchmark test again. l did not set my resolution to 1024x576 for the 576p run and 1280x720 for 720p, could this be the problem with my results?.
So re-ran the two benchmarks again with my i7 930:4.030GHz not 4.217GHz and GPU's at stock, Catzilla is showing SLI -
Test 1 - 1024x576[576p] Score=21074 / Test 2 - 1280x720[720p]=19072.
According to Openhardware Monitor boost is working during the test's Max Boost > GPU 1=1058MHz / GPU 2=1084MHz.
Do these results make better sense.
Cheers,
Oldphart.:confused: LOL
Cheers,
Your results were fine, with Catzilla you can get some really bad CPU bottlenecks so to get the same score @576p and 720p is possible and nothing to worry about.:)
I just needed to know that you were running the GTX 670s in SLI.:)
And on the scoreboard.:)
