GTX680 to GTX780 - Which One GTX780 or GTXTi
10 Jan 2012
NW UK
Hi guys, I'm ugrading this week from GTX680 to GTX780 but which one?
Whats the difference between GTX780 and GTXTi versions?
PC spec in Sig
Used predominantly for BF3 and BF4 etc......
Lew
The Gigabyte Windforce and Gainward Phantom are both great value at well under £400. EVGA'S SC ACX is £400 if you want to stick with them.
As for the difference between the 780 and 780ti, the big one for me is the £200 higher price tag. Have a look at some reviews of the 780ti to determine whether the price difference is worth it to you.
780ti review thread: http://forums.overclockers.co.uk/showthread.php?t=18555565
PC spec in Sig
Lew
If your after a 780 just get stock, They cool and clock very well, As for the "Ti" it has 25% more cores and a 1GHZ higher clock on the memory *7GHZ* so making it roughly 10-20% faster than a standard 780 in various benchmarks/games, Think of it as a 780 on steroids :p
Thanks Flax, will look at review
The GTX680 has eaten anything thrown at it, until BF4 :(
Needs an extra 1GB RAM me thinks, so upgrade is for another 1GB of RAM rather than FPS increase
How do you overclock a GPU?
Is it really easy and foolproof?
Can it be done in software or does it need to be done in BIOS on GPU?
Easy peasy. Just download EVGA Precision X and move a couple of sliders until it becomes unstable (test in games or benchmarks such as Unigine Heaven and Valley)
May get shot for saying this, but considered a HD7950?
I would like to know at what resolution he is playing at before telling him to downgrade to a 7950, just for the 1GB extra of VRAM. The game is new and supposedly optimised for AMD, Nvidia will have better drivers out soon and Dice will hopefully sort out any issues.
If a 680 is having performance drops at 1080P, I guarantee a 7950 will have the same.
