Undercounter lights went it tonight after I got back from work, You got to love LED Strip Lights!
How did you hide the wiring and where are they powered from?
Firestar_3x;25286383 Jobs for this week said:Use a a rigid pipe venting kit, don't rely on that flexible pipe they supply, used one totally collapsed after a few months.
With regards to dimmers, look at the Varlight trailing edge dimmer, available in a range of finishes, & 1-4 gangs, it's suitable for mains & also led lamps if you decide every to use them.
Figure out how to vent hot air from under the stairs caused by new server
Have you got a picture? Maybe we can help?
I've seen someone that fit a vent in the stairs so it vents hot air from the cupboard. Is that an option?
Yeah I think that might be what I do. I was either thinking a normal passive vent or maybe drilling a 120mm hole for a fan to have something actively drawing the air out.
I'd put up a picture but it looks terrible at the moment due to the fact that I'm using 2 bookcases as a rack![]()
