will the wireless charger work if you've got a case fitted?![]()
Is it possible to charge multiple devices at once with QI chargers or does it only work with one at a time?
Anyone else having an issue with the microphone?
I'm getting many callers saying that they cannot hear me correctly - the volume is very low. Anyone else noticed this? If I shove my SIM back in my old Nexus 4, everything is OK.
It is getting that bad on the Nexus 5, I'm going to see if they will swap the handset for one with a functioning microphone.
i think its one at a time but the mats usually have enough space to hold one device anyway
That's a shame.. do you know if the technology behind the mats could support it? It would be awesome if there was some larger mats that would do it eventually, it would save me some plug-sockets!
Anyone else's Google Play via PC browser saying "you don't have any devices"? I am sure this started happening after clearing data for Framework etc.
I don't know when it happened or if it's always been like it but my N5 doesn't show up, my N7 and S4 both do though.
I had lots of weird issues after clearing framework etc. In the end I did a factory reset and all is well again. With Google+ I uninstalled the updates and it doesn't suck the battery now and I can have Google Now enabled.
Just want to confirm if everyone's vibrate 'device' feels a bit... floppy? Underpowered? Compared to my S4 which is very... fast? Strong? Tight? (hard to describe these things!)
Just wanted to make sure it was normal and not faulty.
So a weak vibrate motor AND a crap mic.....? On top of a crap speaker..
Not liking the sound of this
TBH, £350 now seems expensive for a device with these design choices...
