290/X or 7990
From the research I've done two PD cores (or a module) is about the same as one Haswell core. Sometimes it varies but yes. Two IB cores are faster by quite a margin tbh. The 8320 at full pelt with full support is about level with a 4670k, and has the same advantage over a 3570k that the 4570k does.
mantle changes the ipc race
wouldnt suprise me if Intel wont be needed then.
It may work the other way and make the difference even bigger, an intel hex core is a beast of a CPU.
Mantle changes the way what goes load, so unless the mechanics are off the gpu will be loaded max, so yea I am sure we will see some scenarios when one processor is the preference but amd optimized for 8core their way makes the ipc redundant in most cases.
can be totally off there we will find out soon anyhow
problem for dice is this is the last dice game in the BF series I bought.
its not battlefield anymore. EA ruined them.
so once Titanfall hits the street I am there.
I ran my R9 290 at 1000MHZ Core and 1500MHZ Memory.
Less than 2% difference according to Gibbo's heaven results with a stock R9 290X.
I don't personally think a 5GHZ PD module is equivalent to two IB Cores at 4GHZ.
I run my R9 290 with a 4.75GHZ 4670K.
Frame rates at 1080p though, I wouldn't think would be wildly different?
The gpu would have a much larger effect on fps for me than upgrading the platform you'd think, given the choice of where to spend the money.
He's never going to ring the bell when you stand at the door waiting in BF4 mode matt.
Best get back into the civvies.
as to be fair its the first time they've screwed me.
:eek:
You better add one of these to your order mate.
;):p:D
yes.
some have changed their system from Intel to amd and its like what I say, in actual gaming practice you be hardpressed to note difference.
a few fps here and there, well cards at high end differ to little unless you run benchmarks.
:eek:
;):p:D
:D
The problem is ive hyped this up way too much that i fear a lot of people are going to be disappointed.
Anyway
"Your OVERCLOCKERS order will be delivered today between 11:45-12:45"
Ash is currently making delivery number 1, you are delivery number 67.
Ash is back, but this time its personal.
:D
Anyway
Good news,
My girlfriend kindly pointed out that maybe this Ash, could be a woman perhaps? maybe it's Ashley?
If it was, you could...COULD explain that this delivery was meant to be here yesterday, and today you've had to take the day off work again when you should be saving kids/Babies/puppies/kittens/OMG i love twilight too...
Bit of luck you'll maybe get two presents today:D:p
A few FPS here and there is what an R9 290X gives over an R9 290.
And you'll already be losing that.
1080p isn't all that now a days, and an 290x and 290 aren't wildly different in end performance.
Good news,
Lol. If Ash is female its quite likely she is tall, broad and has blonde spikey hair, as well as driving a truck and walking like John Wayne.
Please say to him "Smell ya later Ash!" after you've signed for it!
I will ask him/her what happened yesterday. :p
Is that really all there is? a few FPS?
R9 290X over an R9 290? Pretty much.
In very extensive benchmarks ; Firestrike, the difference is a lot more, in gaming? Barely anything, and you'd have lost that with the FX83 anyway, so it's entirely pointless getting an R9 290X over an R9 290 with his set up.
But it'd be interesting to see, I'm pretty confident I'd out bench him with games (Say 20 from the last year)
The difference between the CPU's depends entirely on GPU set up, resolution and games.
Interesting, should be good to see, what Cpu are you using Mart?
