Recently got hold of a 4k res screen and im getting lots of instabilities on the most recent drivers on my titan sli.
the none 4k res screen and everything is lovely stable.
4k is amazing btw![]()
4K just works and performs all round better on AMD atm.
Both the Radeon R9 290X and the GeForce GTX 780 had no issues being setup and run at 4K Ultra HD resolutions on our Windows 7 64-bit test system. Everything just worked right after the latest driver was installed and we were up and running at the monitors native resolution of 3840×2160.
Read more at http://www.legitreviews.com/amd-rad...780-at-4k-ultra-hd_127129#ZGJYXfzjOsjgt3oy.99
Both Nvidia and AMD had absolutely no troubles setting up the 4K monitor. As long as you have a graphics card that supports 4K, has a DisplayPort 1.2 MST port and is using the latest drivers then we can’t forsee you having any issues.
Read more at eTeknix
As for setting up the 4K display, it seems that setting it up is a bit better now on the GTX 780 Ti. When we launched each game, we did not have any trouble setting the resolutions this time. In the past, we have had some issues, but this time it worked flawlessly.
Read more at http://www.hardocp.com/article/2013...0_ti_vs_radeon_r9_290x_4k_gaming#.UoNGffm-1cY
got the asus 4k screen.
I have a really good comp
4770k@ 4.5ghz
16 gb ram
2 x ssd raid
2 x titan
Performance is not what I would expect (yes I know its 4k!) but others are getting better results than I am plus the instabilities are obviously quite vexing.
The op says different it seems.![]()
The OP is noticing a lack in frames, or at least less than he was expecting - something which is obviously apparent no matter what GPU you use at 4K.
Obviously the problem lies else where![]()
Well your own reference disagrees with you, don't you think it could be something other than a hardware issue?
Thanks for playing.![]()
If you have the money at hand then fine but 4k is a marketing gimmick designed to fill the gap until 8k is available. 8k is being broadcast and tested right now in Japan
