- 12 Jun 2006
Finally.
I took cover, prayed that no one would steal my boat, jumped out my boat and repped from the water![]()
Why can't any of the soldiers hold their breath underwater? It's unrealistic.
I barely went under for a minute before "KIA". They should be able to last at least 5 minutes underwater, especially the marines/assault class.
What level are you now?
How many hours of battfield does one need to play to get 53-0 scores, because I'm sure as hell a long way off![]()
BF4 Patch R9 Information:
We are happy to report that the PC Battlefield 4 game update will go live tomorrow, November 14. The main focus of this update is threefold:
1) Reduce the number of crashes
We believe this update will solve a large portion of the most commonly occuring game crashes, and the improvement in overall stability should make a big difference for many players.
2) Eliminate a network sync bug
If you’ve been experiencing situations in multiplayer where it appears that you are taking damage from enemies through walls, you might have been the victim of a network sync bug. In this game update, we have identified and eliminated one such bug that caused this type of gameplay experience. We are continuing to work on more multiplayer optimizations concerning network performance.
3) Improve Network Smoothing
We have made some improvements to the ”Network Smoothing” functionality that you can find in the OPTIONS>GAMEPLAY menu. The Network Smoothing slider governs a group of settings that aim to produce a tighter multiplayer experience based on your specific packet loss situation.
If you’ve been experimenting with the Network Smoothing slider earlier, it might now yield better results. If you haven’t tried it before, please explore this setting and set it to the lowest value you can without experiencing graphical glitches in the game. By setting it lower, you can get a tighter multiplayer experience, depending on your specific network situation.
More details upcoming
Besides the above mentioned focus areas, this PC game update contains a number of other fixes and tweaks that we will detail once it’s live.
This game update for PC goes live around 10AM UTC/2AM PST November 14. Your Origin Client should acknowledge and automatically download this update for you, as usual. Otherwise, you can right click your game in the client and select ”Check for Update”. There will be a Battlelog maintenance downtime for about an hour as this update goes live. During this time multiplayer on PC will be unavailable.
We at Fragnet will patch all servers at the same time as the client update and Blaze downtime.
We will release full patch notes for this game update later, but the three items mentioned above are by far the most important changes in this update. We understand that stability has been rocky for some players, and hope that this update will make the game run smoother and more stable for you. Let us know in the comments below.
Same here, I really want it. I did enjoy BF3, but I just resubbed to WoW so I don't feel like I'd get the most out of both of them if I buy this as well. The game just seems too buggy which sucks, because launch when everyone is levelling is the best time to get in on these.
Did you not thing to switch to the 4th position? Or were you doing this on purpose in case someone nailed your boat while you were repairing?
Inbound for tomorrow (Details from Fragnet my server host).
A dice patch, god help us.![]()
I've been randomly getting KIA a lot todayespecially parachuting I'll be about 6 foot off the ground and suddenly KIA for no apparent reason
Got everything setup. 22" 1080p, Gigabyte 770 4GB edition, everything at max and staying at 60fps.
So nice to see everything isn't cluttered up compared to a 20" 1600x900 resolution.
