OS is Sigma's Optical Stabilization (IS), HSM is the focusing motor for quiet quick focusing.
The Sigma 17-70 should be a good walkabout everyday lens due to its features, but I haven't tried one to know what the picture quality is like. I have owned both a Tamron 17-50 f2.8 (non VC) and 28-75 f2.8, both cost about £180 second hand and really enjoyed using both.![]()
I own the 17-70mm and have owned the Tamron and much prefer the Sigma.
The focus's faster and closer, the OS is great and the focal length more versatile.
but isn't the sigma an equivalent focal length built for non full frame cameras meaning it can't be used on a full frame?
Conversely, If i opt for the Tamron 17-50 f2.8, i take the focal range would actually be 27-80mm on a non-full frame.. Unless I'm misunderstanding eveything..
I'm looking to invest in a decent standard 35mm - 70mm standard lens for a Canon 400D. Probably prepared to spend up to around £300.
Any suggestions or recommendations?
Thanks
So basically avoid lenses that are designed for APS-C cameras ( non full frame)? if intended to use it on a fill frame later.
No, not at all, buy lenses for what you have now. Even if you go full frame I'd say keep the 400D anyway. Two bodies are always a good idea.
Don't get too hung up on the full frame focal equivalence, I probably confused things, apologies. Once you know how 10, 18, 50 and 70mm look through the viewfinder on your camera, that's all you really need to know.
I guess there's always an oppertunty to sell if I go down that route. I already have a Canon 50mm Prime f/1.8 but not used it much yet.
So just to be clear on this .. on my 400d, the 17-50 will be is will be 27-80mm as it's a APS-C type camera, always multiply the focal lengths by 1.6?
If I use a 35mm lens on a standard camera it will be 56mm.. but if I use it on a full frame, it is quoted 35mm. Have i got that right?
.. snip..
]That a very useful clear and precise post Andy90. Thanks]
I have decided to go for the Tamron SP AF17-50mm f2.8 . I don't think it designed exclusively to crop lenses:
http://www.amazon.co.uk/Tamron-AF17...-Mount/dp/B002OED6ZQ/ref=cm_cr_pr_product_top
I've just seen this in camera world
http://www.cameraworld.co.uk/used-tamron-17-50mm-f2-8-di-ii-yc-canon-eos-fit.html
I take it they are not the same lens.
