I'm just stating my opinions, and you are turning this personal.
Rather than accusing people pulling figures out of thin-air, how about composing a list of all the games that uses 8 cores?
I already have yet you seem to have ignored it. Battlefield Bad Company 2 supports six cores. It also supports Quad SLI and Quadfire. BF3 supports six, Crysis 3 and Far Cry 3 use 8, Crysis 2 uses at least six, BF4 uses eight. Metro doesn't bother with the CPU much and neither does Tomb Raider, yet, it does use six. Bioshock Infinite is so easy to run it doesn't matter, and that pretty much covers the entire last year of gaming.
There are some older games for you. As for turning it personal? I think you'll find it's you doing that. Turning up in a thread and talking nonsense with your nonsensical facts and figures. Maybe if some one did that to you you'd take it personally, most likely because it's a terribly rude thing to do. Even more so when it's without any basis.
			Also stop turning this into accusing people of "hating" AMD when that's not what it is about. I have nothing against the FX8 and the value it represent...I do however against people giving misleading/inaccurate information about performance of hardware when giving people advise
OK first off you must either hate AMD, or, spend your life going around rubbishing things for another reason. So far everything negative you've said about the FX CPUs is either not true or just spiteful. You do have something against the FX 8 because you've done your level best to rubbish it as much as you can. As for misleading? you haven't posted a single link to back up any of your claims, which you are slowly relinquishing as the pages pass. Tell me, who has done the most work here to prove that what you're saying is baseless and full of lies? oh, that would be the AMD owners you've tarred with your brush of being innacurate.
			When talking about hardware, it should involve mentioning both the pros and cons no? Everytime when people mention games that don't use up to 8 cores, you just brush it off as "frame rate is good enough even if it's slower" and keep banging on and on about future games and 8 cores, like it is wrong for people to consider performance for existing/current games, which just so happen most of them don't use more than 4 cores.
I did post the pros and cons. As for considering the future? that is all you can do when even so much as saying the word computer.
			You always avoid talking about these existing games and keep generalising them as "dated single core games", despite many of them were released within the last 2 years. You are keen on not pointing out the fact that in these 4 cores (or less) games, the FX8 are essentially no quicker than a FX4, nevermind reminding people that the i5 would be quicker in these situation.
As I've continually said if a game only supports two cores or even one core then it's dated. Whether it's dated by its release date or the fact that the software house who wrote it were too lazy to embrace modern PC hardware? I don't care, as both of them are not down to poor hardware, only poor software support.
Funny how you then go on to add your analogy of how a FX 8 can be no better than a FX 4 yet, don't go on to mention how a 4670k can end up being no better than a two cored Pentium.
However I do take onboard what you've said, but you need to remember that Vishera was a massive step forward over Zambezi and as such finally made the IPC good enough to take care of crap games that only support a couple of cores. Which is why if you can find one you'll see that any honest truthful review shows Vishera as being a great technological step forward.
			Also quite a lot of double-standard is going on as well: when i5 is a good margin faster than the FX8 at sub 60fps, the response would be "doesn't matter if the CPU is bottlenecking the graphic card, as it is still delivering playable frame rate"; now with FX8 being faster than the Sandy i5 in Crysis 3- which the extra performance won't even be the case if just using a single GPU card, you are making sure that it get highlighted and noticed, despite mentioned "so long as the FX8 can keep the frame rate above 60fps, it doesn't matter how much faster the i5 is" (granted I'm not 100% certain was it you or teppic who said this).
I benchmarked all of recently released titles going back over the entire year on my CPU. The lowest minimum I saw was out of Crysis 3. 39 FPS.
Personally I tend to agree with science. If a game provides me more than 26.7 FPS as a minimum then it's playable. So I see that as playable.
However, I do find it odd that once you've been shown that a FX CPU (six core or above) does a pretty reasonable job of running any game well you then switch to multiple GPUs. Now we're bottlenecking multiple GPUs. However, my data tends to show that if there is bottlenecking going on with my rigs (plural) then it's either slight or it isn't happening.
If Intel's IPC was as wonderful as people make out I would never have bought an FX in the first place. But then seeing is believing is it not? if it wasn't for the fact that even at closing in on 4ghz my Sandy wasn't cutting it I would have never felt the urge to change it, given I'd only had it 11 months.
			I don't really think you are subjective enough to talk about performance of Intel CPUs (especially with you sensational "FX8 is giving me double the frame rate over i5" claims), because of your (unhappy) experience of using non-K Sandy i5 CPU which cannot be overclocked and (happily) to a highly overclocked FX8. You cannot compare your experience of using a locked i5 2400 to a highly overclocked i5 2500K. Also, nobody who has a clue about gaming performance would tell others to "look at Cinebench, Winzip, Firestrike CPU scores/results". Yes those benches would give good indication of how the CPUs would perform in context of those applications, but they are just that, and shouldn't be used as representation for gaming performance.
I've already covered other game results in this thread. But, if you wanted to see more (so that you understand why your older games are less of a worry foir Vishera than you think) then this should do the trick.
The other stuff you talk about? is what the AMDs are bloody brilliant at (productivity and encoding, Xsplit and stuff) which I've not even touched on.
			And for the last time, I don't hate AMD. Most of us who you guys keep accusing as Intel fanboys are the probably the ones that want AMD to surprise us with a bang for bucks CPU more than anyone else- equal performance at lower price much like the 290s graphic card comparing to Nvidia's offering...but that is that, this is this- when someone is not giving the facts about the Piledriver/FX8, speaking out doesn't make us an Intel fanboy.
When you go around telling porkies and deliberately pulling false figures out of a hat to rubbish something/some one it's usually because you don't like them. So either back up what you are saying with data or don't say it.
I've not seen a single shred of evidence to back up your facts, yet, have spent the duration of this post posting facts about AMD processors for you. Which has slowly led you to stop posting figures and facts out of thin air.
So I'm asking you again - please find me some unblinkered evidence to back up what you are saying or please, stop saying it.
You've said that in older games Vishera suffers. I've posted you data that shows that yes, whilst they may not offer up the same performance as a chip costing more money they can still do everything the Intel does. With aplomb.
			There's definitely no criticising about the performance of FX8 in 8 threaded games for their asking price, HOWEVER, it is only in those
specific games- perfect environment of game engine using 8 threads can the CPU be utilised to its full potential. For vast majority of the current games, it DOES NOT use use up to 50%+ of it full capability and no...in lots of these games the FX8
is not capable of holding a solid 60fps.
As it stands at the right now, if current and new 1st person games is all someone interested in, the FX8 would be a good choice; however for anyone that play wide range of different genes of games (particular strategy games and mmos that doesn't has the big publisher's names i.e. EA on them), the i5 will still offer much better performance far more times than it is not at a slight price premium.
Piledriver is actually very much like the Richland APU...it's has made decent progess and toward the right direction, but not quite there yet. Yea come to think of it, what do I care people blowing money meaninglessly going from i5 to Piledriver? Considering that it would mean more funding for the development on AMD's next gen 8 (or more) cores CPU/platform and has better chance to become better (which I would upgrade to if the performance and price is right), I should encourage people to blow more money on Piledriver meaninglessly more often
I've based my opinions on the most recent games. That's usually what one tends to do, not dig up games from two plus years ago and say "Hmm not sure it'll run that well !".
Oh and just for good measure.
