High End Rig - Check Please
25 Jul 2013
Kent
Hi Guys, going to be ordering the parts for my new rig on Monday morning and wondered if you anyone could help me with finalising the build.
Things I want:
-Intel 4930k hex core
-AMD 7990 6Gb
-32Gb RAM with room to add another 32Gb in the future
I already have an H100 for cooling the CPU, am i right in thinking i can take advantage of quad channel memory?
I'm liking the look of the Corsair 500r case, providing everything is going to fit (I think it will).
Budget is basically as cheap as possible while fulfilling the above requirements.
Many Thanks.
What`s your overall budget and have you any components you can reuse?
Do you need an OS?
And Yes, you can use quad channel, as that is what the chip is optimised for.
I think it's a waste spenidng nearly £1500 on these components (which you DO WANT!) and not treating them properly, in my eyes.. I would personally do something like this, as id:
  • Want to see my components
  • Want to overclock them to the max
  • Have them run quietly
YOUR BASKET
1 x Asus HD 7990 6144MB GDDR5 PCI-Express Graphics Card £439.99
1 x Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74930K) £439.99
1 x Patriot Viper "Black Mamba" Generation 3 32GB (4x8GB) DDR3 PC3-12800C10 1600MHz Quad CHannel Kit (PV332G160C0QK) £239.99
1 x Gigabyte X79-UP4 Intel X79 (Socket 2011) DDR3 Motherboard £209.99
1 x Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) £134.99
1 x XSPC D5 Dual Bay Reservoir/Pump Combo V2 £109.99
1 x EK Water Blocks EK-FC7990 SE - Acetal £101.95
1 x BeQuiet Pure Power L8 730W '80 Plus Bronze' Modular Power Supply - With 120mm Silent Wing Fan Built in £89.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £79.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99
1 x EK Water Blocks EK-Supremacy - Acetal £49.99
2 x XSPC EX240 Crossflow Radiator £44.99 (£89.98)
4 x Akasa AK-FN058 Apache Black Super Silent 120mm Fan - 4 Pin PWM £9.98 (£39.92)
1 x BitFenix Alchemy 24pin ATX extension 30cm - Blue £8.99
2 x XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Blue/UV Blue £6.49 (£12.98)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Blue £5.99
2 x BitFenix 6+2-Pin PCIe Extension 45cm - sleeved blue/black £5.99 (£11.98)
2 x Mayhems Ultra Pure H20 Watercooling Fluid 1L £4.99 (£9.98)
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Blue £4.99 (£9.98)
10 x XSPC G1/4" to 3/8" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£29.90)
Total : £2,182.55 (includes shipping : FREE).
Motherboard and ram are out of stock
I got carried away ..............................
YOUR BASKET
2 x Inno3D GeForce GTX 780 iChill HerculeZ X3 Ultra DHS Edition 3072MB GDDR5 PCI-Express Graphics Card £479.99 (£959.98)
1 x Kingston HyperX Beast 32GB (4x8GB) PC3-17100C11 2133MHz Dual Channel Kit (KHX21C11T3K4/32X) £289.99
1 x MSI X79A-GD45 Plus (8D) Intel X79 (Socket 2011) DDR3 Motherboard £153.95
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £146.99
1 x Antec High Current Pro 750W Modular '80 Plus Gold' Power Supply £129.95
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £105.95
2 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99 (£131.98)
1 x BitFenix Alchemy Cable Bundle - White £28.45
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £25.99
1 x BitFenix Alchemy Premium Modding LED Strip - Connect White 60cm £25.99
1 x Corsair AF120 Quiet Edition Low Noise High Airflow - Dual Pack (CO-9050002-WW) £19.99
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - White £6.98
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - White £6.49
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - White £5.99 (£11.98)
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - White £4.99 (£9.98)
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - White £4.49
4 x BitFenix Alchemy 2pin I/O extension 30cm - White £3.95 (£15.80)
Total : £2,559.24 (includes shipping : £24.45).
That is fair enough, im just telling it the way I see it though..
The 7990 gets hot and loud and has many intamces of coil whine, so the only way id have it is watercooled.
I am 100% with you but watercooling can seem daunting... especially when you just wanna game and not bench haha
But as mentioned, I like your thinking bruv
My spec, now with everything in stock:
YOUR BASKET
1 x Corsair Dominator 32GB (4x8GB) PC3-12800C10 1600MHz Dual/Quad Channel Kit (CMP32GX3M4X1600C10) £239.99
1 x EK Water Blocks EK-FC7990 SE - Nickel £114.95
1 x EK Water Blocks EK-Supremacy - Acetal + Nickel £52.99
Total : £2,142.50 (includes shipping : FREE).
YOUR BASKET
Welll, I suppose the OP can always sell his H100. :D
Some very nice specs there :) and I agree maybe I went around this the wrong way.
In all honesty, noise and efficiency aren't super high on my list and a I agree the 7990 is a bit of a beast to tame if I'm looking for a simple build, it's power to pound ratio is just too hard to deny!
Put simply, I would like to make use of the h100 that I already have, custom water is best saved for when I'm a bit more confident with my builds.
My main reqs are that I want a strong processor that isn't a 4770k and isn't almost pushing £1k and is a good overclocker, which I think the 4930k fulfills nicely.
Next up, 32gb of quad channel ram, with a motherboard that can later take another 4x8gb in the future.
Graphics card, as I mentioned, I'm finding it hard to forget about the 7990 although I'm aware of its noise, power and heat issues. I'm the 780 ti to be another contender but it's over £100 more. Also the 7990 can be found new for the equivelant of just over £300 new at the moment which makes it all the more attractive.
Appreciate all the input so far
