- 17 Apr 2012
Hi Guys
Need your techie help.
Said I would take a look at a friends sons pc....It wont boot up.
Its pretty old...
When I first turned it on it was artifacting on the bios screen, So I think its safe to say the card is knackered/on its way out (9800 GTX 512MB
So I have just put a spare 5770 in. That got rid of the artifacting problem.
But it still gets to the same screen. The drive has apparently been wiped but they couldn't get windows to reinstall.
Things I have tried:
Switched GPU's
switched hard drive power cable
Tried a hard drive with a working copy of windows, but it gets to the loading screen and blue screens. to fast for me to see error code.
Have also checked boot order and hard disk is set as 1st priority, is that right?
XFX 780i SLI mobo
Intel E8400 CPU - (noticed the Multiplier was on 9, dont have a clue what that means though)
700W Fatality PSU
Reset CMOS
This is the screen showing currently. Is this what it should be showing if there is no OS?
Thanks guys
dont know if this is the right forum btw
Its pretty old...
Switched GPU's
XFX 780i SLI mobo
700W Fatality PSU
Reset CMOS
Thanks guys
