Battlefield 4 Thread ~ Server details in opening post ~
I need to format my PC as I'm moving from windows 7 to windows 8.1. Anyway of not downloading battlefield again after reformatting?
can you save your origin folder to a different disk ?
if you can't copy it then you'll have to re download afaik.
just had a screen freeze and had to alt tab out, not had one of those since the first couple of weeks after release :(.
Today has been a lot more stable for me (i even risked a boost and survived!), no disconnects or crashes, just the odd sound bug.
RE the stealth just, i will get a kill with you. One day.
Ok just copy it to another disk and put it back after I've installed origin.
So far no crashes but "netcode" still as quirky as ever - lit up a guy running straight at me to no effect yet managed to headshot a sniper at 181m with the AK5c with an instinctive snap shot that was aimed way too low and at best at that range would have hit him in the foot and even that would be stretching credibility :(
yup, when you've got win 8 installed, install origin and start the download of bf4, then pause it, copy the folder into origin games folder then restart the download, it will check all the files and that should be it.
don't know if you've made many audio/graphics settings changes, if you have get a copy of the settings folder, usually in "my documents\battlefield 4"
Just played another hour after getting home from work. Still haven't had a "Battlefield 4 has stopped working" crash since the patch.
I don't want to jinx it but its looking good.
GPU usage has improved immensely as well on my sli 670's
What sort of average gpu usage are you getting now?
Bf4 lag haha.
xTheOutlawed if you see this guy ban aimbotter . couldnt find his bl but joined a rush soon map started 40-0 after one minute left before end of round.
