- 21 Jul 2005
- Officially least sunny location -Ronskistats
People really need to learn how to interpret information from graphs properly and realise what they are actually showing. The FX8350 needed 4.50GHz to match the i7 4770K at 2.50GHz before able to reach the GPU limit at 41fps. What this also means is that for the FX8350 at 4.50GHz, dropping from max settings down to medium to reduce GPU limitation will not increase frame rate much due to CPU bottleneck;
Yes interpreting the graph is not really processed by some people.
Let's not forget DM summed it up nicely (in another thread) that if designed to run on an AMD CPU it is not the hardware that would cause the bottleneck.
