Didn't think you'd notice a difference in hit reg while using mortars?
 if server slight latecy you have to lead or pull slightly as you do normal guns
 if server slight latecy you have to lead or pull slightly as you do normal guns  anyone who plays a lot can adjust and plays on. most will just whine though instead of leading shots due to latency
 recorded will try for a forty on there or zavod later
 died quite a few time on lockers last night because I was stuck on 20hp, spamming for a med pack but getting diddly squat!
 died quite a few time on lockers last night because I was stuck on 20hp, spamming for a med pack but getting diddly squat!  then getting shot 2 secs later while trying to wait for hp regen or chasing after any medic....they just don't get the hint
Helicopters as per BF3. For Jet's a joystick is not needed. Bind space to pitch up.
Dice have completely dumbed down Jets making it much easier to turn without having to maintain constant 310/315.
WTB more health on revives. As much as I appreciate any revive from a random in a pub server....It's really annoying when they do a zero charge so you're left with 20HP....then they don't drop a med pack down.died quite a few time on lockers last night because I was stuck on 20hp, spamming for a med pack but getting diddly squat!
Don't accept the revive then??
 suppose it is a bit much to assume that people would have the logic to throw down a medpack when reviving as I'm sure they'll have noticed, when they get revived, how low their HP is xD
 suppose it is a bit much to assume that people would have the logic to throw down a medpack when reviving as I'm sure they'll have noticed, when they get revived, how low their HP is xDok, is that mouse and kb for helos?
Yep KB + Mouse all the way for Heli and jet's.
I've been playing on no explosive locker conquest server for last few days and not had any server crashes.
But hit reg is still terrible at times, openly empty clip on to a guy from behind and the guy and turns around and shoots me one shot with lmg.
goto the folder documents/battlefield 4/settings
and find the file PROFSAVE_profile
change the line GstAudio.AudioQuality 0(may be different)
to:GstAudio.AudioQuality 4
this changes it to wartapes quality audio
then find the line with GstAudio.SoundSystemSize 20(may be diff)
and change it to GstAudio.SoundSystemSize 64
or GstAudio.SoundSystemSize 32(if your sound card is cheapo)
this changes the amount of audio channels BF4 can use, 20 is really really low, which means in big audio situations with a lot going on, the sounds get cut off.
and this one is optional, GstAudio.StereoMode 0
to GstAudio.StereoMode 1
so to recap the lines should be:
..and Caspian Border...
Try this, might work for sound loop
