Battlefield 4 Thread ~ Server details in opening post ~
Can't they at least redo Operation Market Garden, Songhua Stalemate or how about Camp Gibraltar (okay it's a 2142 but...)!!
I don't mind one or two maps from the past games but some of the really old maps were far better layouts.
Didn't think you'd notice a difference in hit reg while using mortars? :p
you actually do :D if server slight latecy you have to lead or pull slightly as you do normal guns ;) anyone who plays a lot can adjust and plays on. most will just whine though instead of leading shots due to latency :D
just had a 31 killstreak on gormand :cool: recorded will try for a forty on there or zavod later :p
best score was previously on zavod was like 75 for like 5 i think.
Apologies for my slow engineering last night.
Was in a tank with Nexus, and Stronk kept saying "help" "FFS repair me" etc. in chat.
I was sat there thinking "what numpty is leaving him flapping in the wind?"
It's only when he said "Mock, help" that I realised he was parked behind me in his seriously damaged tank, waiting for me to get my arse out of the HMG and do my job.
Whoops.
Sorry Stronk.
On the plus side, that game saw me unlock RPG (love it) and DMRs, so not all for nothing :D
WTB more health on revives. As much as I appreciate any revive from a random in a pub server....It's really annoying when they do a zero charge so you're left with 20HP....then they don't drop a med pack down. :( died quite a few time on lockers last night because I was stuck on 20hp, spamming for a med pack but getting diddly squat! :( then getting shot 2 secs later while trying to wait for hp regen or chasing after any medic....they just don't get the hint :(
Guys, Hi!
I have a problem with my BF4 (pc version). When the map is changed I get blue screen. Do you know how to fix it?
P.S. It happens only during changing the map.
Don't accept the revive then??
yea but I'd rather try and be alive :p suppose it is a bit much to assume that people would have the logic to throw down a medpack when reviving as I'm sure they'll have noticed, when they get revived, how low their HP is xD
Is it just me or when you were revived in the beta you were able to shuffle along the floor a little if you wanted before you accepted? I'm pretty sure I remember numerous instances where I was revived in a door way, so I would crawl back behind the door/wall and then hit accept?
I've been playing on no explosive locker conquest server for last few days and not had any server crashes. :D
But hit reg is still terrible at times, openly empty clip on to a guy from behind and the guy and turns around and shoots me one shot with lmg.
yea last night on lockers I was using the uhhh LSAT LMG? so 100 round clip... I was outside and jumped over a snow drift where I knew enemies where behind. so I popped over and landed behind them and there were 3 of them all within about 2-3 meters space...I let rip....took 60ish bullets to drop all 3 of them....I was just strafing around them wondering why the **** they weren't dying....seriously takes the biscuit sometimes!!!! even with spread and suppression they should have been dead much faster! seemed that they would sponge a load of bullets then they HP would suddenly drop after about 20 bullets......rather annoying.
The game is still largely unplayable on my system which consists of an FX-8150 clocked at 4GHz, 16GB DDR3 1600MHz, and a GTX 670 2GB. Playing on Paracel Storm resulted in performance dipping to as little as 9 frames per second. (On the high preset, no less!)
I could comfortably play BF3 on ultra with 4x MSAA!
I've tried everything from disabling power saving features, to unparking my CPU cores, and running the DirectX executable from the game's directory. I'm almost certain it's resultant of poor optimization, and not my system! It runs BF3, Crysis and Metro Last Light flawlessly on ultra!
Asked a while ago. Will ask again.
Freezing with sound loop. Still happening to folk? Seems to be the only real problem i have at the moment.
Not suffered from random crashes or server crashes. FPS is generally fine, running sli 670s......just this soddin freezing on larger conq maps.
Try this, might work for sound loop
goto the folder documents/battlefield 4/settings
and find the file PROFSAVE_profile
change the line GstAudio.AudioQuality 0(may be different)
to:GstAudio.AudioQuality 4
this changes it to wartapes quality audio
then find the line with GstAudio.SoundSystemSize 20(may be diff)
and change it to GstAudio.SoundSystemSize 64
or GstAudio.SoundSystemSize 32(if your sound card is cheapo)
this changes the amount of audio channels BF4 can use, 20 is really really low, which means in big audio situations with a lot going on, the sounds get cut off.
and this one is optional, GstAudio.StereoMode 0
to GstAudio.StereoMode 1
so to recap the lines should be:
