- 20 Jan 2010
- Bath
Brilliant have added you. Has anyone got a ditto friend safari because i'm struggling to do any breeding above 2 IV's without one. Also looking for one with Froakie and fletchinder with hidden abilities.
If your interested let me know if you've added me![]()
I can help you out with both of them! With the Froakie will it be a special or physical attacker? I'd personally recommend physical, as the moves you'll end up using the most is Matt Block then U-turn (rinse and repeat)
Assuming you want to go physical I can give you a Female Jolly (+Spd - SAtk) Protean Froakie x/31/31/x/31/x and a Male Protean Froakie 31/x/31/x/31/31. Then all you need to do is put the everstone on the female and destinyknot on the male and before you know it you'll have a Jolly Protean Froakie with 31/31/31/x/31/31.
As for the fletchinder I can give you Female Jolly Galewings Fletchling 31/31/31/x/x/31 and a Male Jolly x/31/31/x/31/31 and you'll have a 5 IV Hidden ability Talonflame before you know it!
I tried Mega Mawile but didn't think much of it but maybe I just got bad matchups, will have to try again.
