I was under the impression that the latest version could read vrm temps on 290/x cards.
Yeah it can I can see them on mind but I don think it's on by default. Enable htm bad boys![]()
Nice gpu score on 3d mark 11 dude I can't seem to get to > 1170 core sad times what settings you using and thanks again for the info what a legend![]()
GPU-Z is supposed to show 290X VRMs, maybe wipe any reg entries etc and reinstall (or delete exe and download again)?
How come there's no scrollbar on your screenshot? Do you see one?
theres a place near where i work that sells aluminium in blocks, and a guy i know has a factory that manufactures Pulleys, and his son makes custom Subaru parts. Between them im betting i can get them to mill me a finned aluminium heatsink to custom fit a 290 with space in the middle to mount my Kuhler 920 Pump, screw points to mount 2 120mm fans to the heatsink. With enough thermal paste i reckon that would do a decent job of keeping the VRM temps down and the gpu coolEnough of these benchmarks. I want to know if this thing plays every game maxed out @1440!!!
. Not uncommon on 290's from what I've read. Hopefully AMD fix that issue soon.The only game I've played so far is BF4, have to say it feels way more fluid and fps are a fair bit higher than GTX 780.
don't you have to disable ulps to get true physics scores with haswell cpu's?
should be mid 13k physics at 4.4/4.5ghz
