- 14 Jun 2004
- Newcastle U/T
*points*
Door
/thread
Door
/thread
I almost agreed with you until I saw the eggs thing. It always seems to be too easy to overcook the eggs in the icrowave.
I have to say I was dubious about the bacon thing, however, the pictures shown seems to have it coming out crispy. I'd have no problem with this. If you're happy to grill instead of frying then I don't see why you wouldn't at least try microwaving. I've been to plenty of greasy spoons that use too much oil in the pan anyway and the bacon doesn't even come out crispy. Now that is disgusting bacon!
It works. Better to cook it on a George Foreman IMO though..with some pork and apple sausage and mushrooms...lots of mushrooms...mmm
Tip: Wrap the bacon in foil before microwaving. You get the benefits of the hot pan effect inside the foil with none of the mess. Wrap it good.
teach us?
Keep eggs at room temp for a start, cold eggs + hot pan = rubbery flavourless eggs.And what, pray tell, is the 'proper' way to make scrambled eggs?
In general the only eggs you should chill are baking eggs, even then I don't wholly advise it.
Decent saucepan (preferably fluted, around 18cm for 3 eggs add 2 cm for every 2 subsequent eggs), over a medium to low heat, big knob of butter in it.
Whisk eggs til just combined, add salt and whisk more if you like fluffy eggs (I don't)
Add the eggs to the pan and stir slowly for big sized scrambles or fast for small, just slowly thicken then mixture is the game, too hot, you burn and get rubbery eggs, too low and you'll be there for hours.
Just before done consistency (depends how you like your eggs, go for 10-20% runnier than you'd like) remove from the heat, season liberally with pepper and consider adding some fresh chopped parsley if you have it.
It's not rocket science it's just good cooking.
Have you ever tried making a little béchamel sauce (with a little nutmeg) as a base and scrambling the eggs into that? Absolutely divine!![]()
Your method had the idea but it lacked detail and technique, it's the little things which make a good cook into a great cook.So, almost precisely the way I posted![]()
