Imgur is much easier.
Also will not work :/
Is there a limit of Imgur as the picture is 140MB.
Are you uploading a tiff?
That TV is crying to be wall mounted
Here is the 60 incher I bought earlier this month. Sorry for the potato pic, tried to show the light behind (dark room w/ phone camera) and came out pretty bad (you get the idea)
Why are you uploading a tiff? Is it for someone else so they can edit?
800x600 JPEG is fine for most forums.
Nice, is that a F7000?That TV is crying to be wall mounted
Correct, floating wall technique with LED strip lights behind. All the AV gear is tucked away and then 5.1 surroundHow did you create this effect? Is that a floating wall?
I got the 55 version a couple of weeks ago; you're right, it's amazing.Yep, 60" love it so far!!
Thank you for wearing trousers.
The beast has arrived....
 The case build quality is so good.Oh do show us more![]()
Enjoy the beastThe case build quality is so good.
