I don't know how to say this...but so many things are wrongly installed (direction wise) in this pic...![]()
the top portion of the pc is ice cold its the bottom im having trouble with, the back little fan is pulling in cold air cpu blowing out along with the big red fan
If your DX error is "device hung" then it's the application that's the problem - lots of people have this error.
Are you experiencing any lock-ups, BSOD, random reboots?
If you have time, you should sort out your airflow and tidy your cables. Here's a picture pull directly from CoolerMaster for your case:cooler master haf 912 plus, the psu was the other way around
You can actually route that cable between the graphic card and the motherboard if that cable is not long enough to go round the back, as in under the graphic card left of the PCI-E x16 slot.I think the cable that goes at the top left of my mobo isn't long enough but the rest should be sound I need to find the screws off the front fan
