WiFi only, thanks
the only difference to the uk is the power adapter
being the 2 pin type in the states
It will have US software on it, but that wont mean much and you should be able to grab the UK version and install it with Odin.
Can cause problems though, I tried this on two Samsung tablets and noticed issues both times.
What sort of issues? because there shouldn't be anything I can think of that would cause a problem.
My Mum's Tab 7.0+ had terrible battery life after I flashed it with UK firmware (rather than the Canadian version). Reset it, reflashed it, tried a different version, same result every time. It'd wakelock and chew the battery in a day.
