Hey, I am looking for 4 new fans for a push pull on my h100i, the two I have at the moment are loud so looking for quiet mainly. Also need to be in the price range of 20-30£ the cheaper the better, but I know to cheap won't last and wont be quiet.
Corsair SP120 are what you want
There are available in dual packs to save a bit of money and also 3 or 4 pin variants.
Good fans aren't cheap![]()
NO, NO NO and NO again, those are CASE fans. they have NO static pressure for radiator cooling. use the SP120's, The Gentle Typhoons or some bitfenix spectre pro's(Not the best choice these, they are alright but nothing on the other two)
dont bother with push-pull its a 1-3c difference at best, more noise and power for not a lot of much. also saves you £25 from having to buy 4.
im ditching push-pull the moment i get a 240mm rad
Any stats to back that up?
If I went push only on my H80, it could free up the top exhaust grill for some VRM airflow.
Are SP fans useless as case fans?
Thanks - that's the first time I've ever really understood that SP fans can be used in place of AF fans.
Depends a lot on what you want to do with it. Good static pressure for case or air cooler is lower than good static pressure for radiators.. and the thicker/more fins per inch the radiator, the more static pressure needed.So whats a good 140mm fan with good static pressure?
Id personally just get 2 very good pwm fans. push pull is only worth it you have really poor fans and or a really thick radiator (which the h100 is not)
