Caporegime
- 18 Sep 2009
- Dormanstown.
I must have misread.
What resolution were you on about for 60 FPS average?
The new intels are coming next year so buying a new cpu now would be a risk.
The 3770K are a dead board now no future chips coming so like a 4770k buying a 3770k would be a waste an maybe a side step in stead of an upgrade.
There's plenty of benches regarding the 3 chips.
His best option would be stick with what he's already got an clock a bit higher wait till next year then buy current gen if there's an improvement.
Given that the WOT engine is poor, what you will say if my statement was "GTX780 @1300 sucks, get a 7950 which is cheaper and performs the same"
(try it yourselves at same maxed out settings)
Picking one game to make a point isn't fair, especially there are so many parameters to consider.
How Sleeping Dogs performs NOW with cat 13.11 on 2 7950s compared to single GTX780 or 290X?
How 2 7950s perform on Tomb Raider, Crysis 3, Bioshock or BF3-4 compared to GTX780 or 290X?
If in doubt see the reviews where the 7990 is and remove 10%-15% performance for stock speeds.
I doubt the next line of Intel chips will bring any major performance improvements (it's the same story each year so far). The only noticeable differences are the temps which seem to get hotter! There's also no point in waiting for the next best thing either as you'll always be waiting. I still say just pop in a 3770k and it'll be fine... It's only a side step for games and other software that are limited to 4 threads.
Anyone upgrading or building a decent gaming rig now should always consider a CPU with more than 4 threads and a GPU with more than 2GB VRAM.
there's plenty of members on here already said the same thing as most have already made the jump an regretted it.
I swapped my 3570k over for a 3770k and i'm happy with my decision as i know i won't be kicking myself later (i sold a spare i5 2500 that went towards the cost of the 3770k and the 3570k is now in another PC). The OP could end up with a real bargain if he finds a good used 3770k and sells his 3570k
Its good when you drop on a decent chip.
But so far your the only person ive seen that's said there happy with the jump from 3570K to either 3770K or a 4770K, every other one has said there wasn't much performance boost during gaming hence why im still running my 2500K.
