So how is the MP in this? is it like MW 1? i didn't like BO 2 MP much....and also is GMG cheapest for it at £30?
I feel your pain dude, tried newest Beta's tonight and still its like playing on a damn commodore 64 (for those that remember)Mine is still running woefully with crossfire enabled.
Hmm, both cards running at around 40% in a MP game....wuuuut
Action packed varied missions, the under water and space levels are interesting, some very interesting special effects in the cut scenes, mp is the better part, bot scraps are interesting, a.i will give you a run for your money, quite a lot on offer in this game, less foul language to deal with than other gamesWhat's the single player like this time?
Bad one
With the 6950 its all running perfect now with no problems at all...silly question I know but did you use amd tool to remove old drivers properly?
Was the same in bo2 with mine for ages till drivers were fixed...annoying they cant get these things sorted before release.
91 fps limit is too low tho...ran no2 fine flat out at 200 fps albeit with reduced settings.
Hope you get it sorted...nothing worse than having a 2nd gpu sitting there doing nothing.
Happy with mine considering gpus are nearly 3 years old.
Action packed varied missions, the under water and space levels are interesting, some very interesting special effects in the cut scenes, mp is the better part, bot scraps are interesting, a.i will give you a run for your money, quite a lot on offer in this game, less foul language to deal with than other games, in fact i can't hardly recall any swearing?.
Utter dross.
At least that's what the first 30-40 minutes was like.
The game insta killed me twice for not doing exactly as I was told in that time.
During which time I'd been allowed to follow someone and use the sprint and jump key. Follow someone in space and use automatic weapons without the fear of damaging the space craft and press the use key. Follow someone in a destroyed city, use a radio controlled dog and do a slow motion door breach.
Yeah I used the Ati uninstall tool, rebooted and installed new drivers. My system is stock apart from the Cpu running at 4.3ghz so my setup is similar to yours.Bad one
I should be receiviing this today or tomorrow. Do you guys recommend it, I got it cheap but still if its unplayable then no point. Was looking forward for an easy pick up and play game.
