Downloaded and ready to go on a USb Stick just in case there are issues with downloading the update over the weekend.![]()
Just got it cheers.
Remember it's the same as PS3 the update needs to be in a folder tree to work.
You need a folder called PS4 and then one in that called UPDATE you put the update file in.
