<<<<< BLACK FRIDAY DEALS: POWER SUPPLIES!! >>>>>
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Got some stonking deals on Power Supplies for you guys, on the best brands, as per all the other deals, the pricing end Midday-Monday or when stock sells out, whichever comes first:-
Akasa Cobra Power 650W Modular Power Supply PSU @ £47.99 inc VAT
The Akasa Cobra power supply series brings flat, low profile modular cables allowing for easy cable routing and better airflow.
The modular cable design allows use of the cables you need to improve internal airflow and reduce clutter for better cable management. Low-profile, flat cable design also helps to reduce friction in airflow and maximises it throughout your computer's chassis.
With a typical 82% efficiency, Cobra is not only saving you money on your electricity bill and is also reducing heat in your computer to extend its life.
Features:-
Modular cable management enhances airflow
Dynamic single 12V rail for power hungry hardware
Thermally controlled ultra quiet fan
Cobra strip cable is neat and manageable
Spefication:-
- Form factor: ATX 12V 2.3
- Dimensions: 150 x 160 x 86mm (W x L x H )
- Typical efficiency: Over 80%
- Power Factor Correction: Active PFC
- Fan:135 x 135 x 25mm, thermal control
- Motherboard connector: 1 (20+4pin )
- ATX12V connectors: 1 (4+4pin)
- PCIe 6+2pin connectors: 2
- SATA connectors: 6
- Molex 4pin connectors: 3
- FDD 4pin connectors: 1
- AC power input: 240V AC
- Protection: Over Power / Voltage / Current Protection
Was [£59.99] Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
Akasa Cobra Power 750W Modular Power Supply PSU @ £59.99 inc VAT
Features:-
Spefication:-
Was [£77.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Akasa Cobra Power 850W Modular Power Supply PSU @ £71.99 inc VAT
Features:-
Spefication:-
- PCIe 6+2pin connectors: 4
Was [£89.99] Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Akasa Venom 550w Modular '80 Plus' Power Supply @ £47.99 inc VAT
AKASA Venom Power 550w modular PSU comes with 80% high efficiency and features a 135mm quiet fan.
- Dimensions: 150 x 158 x 86mm (W x L x H )
- Fan: 135 x 135 x 25mm, thermal control
- Motherboard connector: 1 (20+4pin)
- Molex 4pin connectors: 6
- FDD 4pin connectors: 2
ORDER NOW
Corsair RM Series RM 450 '80+ Gold' 450W Power Supply (CP-9020066-WW) @ £65.99 inc VAT
Corsair RM Series power supplies are fully modular and optimized for silence and high efficiency. Zero RPM Fan Mode means that the fan doesn’t even spin until the power supply is under heavy load, and the fan is custom-designed for low noise operation even at high loads. 80 PLUS Gold rated efficiency saves you money on your power bill, and the flat black cables are fully modular, so you can enjoy fast, neat builds. And, like all Corsair power supplies, RM Series is built with high-quality components and is guaranteed to deliver clean, stable, continuous power. Connect it to your Corsair Link system and you can even monitor fan speed and +12V current directly from your desktop (additional cable required for 450W-850W units).
Product features:
- Optimized for Silence: The components used to manufacture the RM Series are manufactured specifically for excellent performance and low audible noise.
- 80 PLUS Gold-certified Efficiency: Highly efficient RM Series power supplies produce less heat and have lower operating costs.
- Flat black, Low-Profile Modular Cables: You can use only the cables you need, and leave the rest in the box for fast, easy, and great-looking builds.
- Reliable, Continuous Power Delivery: Corsair uses high-quality internal components, and RM Series power supplies are guaranteed to deliver clean, stable, continuous power.
- Corsair Link Compatible: RM Series power supplies connect to Corsair Link software for real-time monitoring of fan speed and power delivery directly from your desktop. Additional hardware required for 450W-850W units.
- The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
- 4th generation Intel® Core™ processor Ready (Intel Haswell and Z78 motherboards)
- 80PLUS Gold certified, delivering over 92% energy efficiency at real world load conditions.
- The completely modular cable system allows you to use only the cables you need.
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer’s chassis.
- High-quality capacitors provide uncompromised performance and reliability.
- A five year warranty and lifetime access to Corsair’s legendary technical support and customer service.
- Active Power Factor Correction (PFC) with PF value of 0.99.
- 135MM NR135L Noise reducing fan. MTBF: 100,000 Hours
- Universal AC input from 100~240V.
- Multi-GPU Ready
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, C TUV US, RCM, TUV, CB, CCC, BSMI, GOST, ROHS, WEEE, ROHS, KC
Was [£74.99] Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Corsair RM Series RM 550 '80+ Gold' 550W Power Supply (CP-9020053-UK) @ £71.99 inc VAT
Product features:
- Multi-GPU Ready
Was [£85.99] Inc. VAT
ORDER NOW
Corsair RM Series RM 650 '80+ Gold' 650W Power Supply (CP-9020054-UK) @ £79.99 inc VAT
Product features:
- Multi-GPU Ready
Was [£99.95] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Corsair RM Series RM 850 '80+ Gold' 850W Power Supply (CP-9020056-UK) @ £99.95 inc VAT
Product features:
- Multi-GPU Ready
Was [£119.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
EVGA SuperNova NEX 750W '80 Plus Gold' Modular Power Supply (120-PG-0750-GR) @ £89.99 inc VAT
The EVGA SuperNOVA NEX750G Gold PSU is a premium quality power supply intended to meet the needs of the most demanding enthusiast systems. Designed with enthusiast needs in mind the NEX series is the best choice to power the next generation of computers. Combining 750W of continous power wtih exceptional performance, stunning efficiency, and cutting edge design and geatures, the NEX750G Gold is what you need to take your system to the next level.
- 5 Year Warranty
- 80Plus Gold certified with up to 90% efficiency under typical loads
- Highest quality Japanese brand capacitors
- Fully Modular
- Quiet 2 ball bearing fan for near silent operation
- High Amperage multi-rail design for max power and stability
- Quad +12V Rails
- 4 x 6+2 Pin PCI-E Connectors
- 9 x SATA Connectors
- 6 x Molex Connectors
- 1 x FDD Connector
- 2 x 4+4pin Connectors
- 1 x 24 pin Connector
Was [£109.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
EVGA SuperNova NEX 650W '80 Plus Gold' Modular Power Supply @ £79.99 inc VAT
The EVGA SuperNOVA NEX650G Gold PSU is a premium quality power supply intended to meet the needs of the most demanding enthusiast systems. Designed with enthusiast needs in mind the NEX series is the best choice to power the next generation of computers. Combining 650W of continous power wtih exceptional performance, stunning efficiency, and cutting edge design and geatures, the NEX650G Gold is what you need to take your system to the next level.
- 5 Year Warranty
- Fully Modular
- Quad +12V Rails
- 1 x FDD Connector
Was [£95.99] Inc. VAT
ORDER NOW
EVGA 600W 80 Plus Bronze Power Supply (100-B1-0600-KR) @ £43.99 inc VAT
With price and performance in mind, the EVGA 600B is the best value power supply for your next build on a budget. With 80 Plus Bronze standard, over 80% efficiency under typical loads, the EVGA 600B is a great choice. Combining 600W of continuous power and Single +12V High AMP rail design, gain maximum power and efficiency while staying protected with a series of over volt/over current protections all bundled into one!
Features:-
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), SCP (Short Circuit Protection), and OTP (Over Temperature Protection)
- Quiet and Intelligent Auto Fan for near-silent operation
- 80 PLUS Bronze certified, with up to 85% efficiency under typical loads
- Double Ball Bearing Fan
Was [£55.99] Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
EVGA 500W 80 Plus Bronze Power Supply (100-B1-0500-KR) @ £39.95 inc VAT
With price and performance in mind, the EVGA 500B is the best value power supply for your next build on a budget. With 80 Plus Bronze standard, over 80% efficiency under typical loads, the EVGA 500B is a great choice. Combining 500W of continuous power and Single +12V High AMP rail design, gain maximum power and efficiency while staying protected with a series of over volt/over current protections all bundled into one!
Features:-
Was [£47.99] Inc. VAT
Only £39.95 inc VAT.
ORDER NOW
Seasonic G series 550w '80 Plus Gold' Modular Power Supply @ £65.99 inc VAT
For the ultimate in low wattage, high quality PSU needs comes the Seasonic G Series PSU with 360 / 450 / 550 and 650w options these units are perfect for any HTPC or mid range gaming system.
- 80 Plug Gold Certified
- DC to DC Converter Design
- Tight Voltage Regulations (±3%)
- Smart and Silent Fan Control
- High Reliable Aluminum Electrolytic Capacitors
- Conductive Polymer Aluminum Solid Capacitors
- Detachable Modular Cables
- High Current Gold Plated Terminals
- 12cm Ball Bearing Cooling Fan
- Ultra Ventilation (honeycomb structure)
- Mulit GPU Technology Support
- Universale AC Input
- 5 Year Warranty
Was [£79.99] Inc. VAT
ORDER NOW
Seasonic G series 650w '80 Plus Gold' Modular Power Supply @ £89.99 inc VAT
- 5 Year Warranty
ORDER NOW
Seasonic G series 750w '80 Plus Gold' Modular Power Supply @ £99.95 inc VAT
For the ultimate in low wattage, high quality PSU needs comes the Seasonic G Series PSU with 360 / 450 / 550 / 650 and 750w options these units are perfect for any HTPC or mid range gaming system.
- 5 Year Warranty
ORDER NOW
Zalman ZM 450W GS '80 Plus' Power Supply @ £28.99 inc VAT
Two-Forward Switching Design minimises switching loss and internal heat for enhanced reliability and stability. By implementing an Active PFC (Power Factor Correction), instead of a Passive PFC with a Power Factor (PF) of 75%, PF has been improved up to 99% while harmful harmonic frequencies have been reduced to meet the Line Harmonic Distortion Requirement of IEC61000-3-2 Class D. Ultra quiet 120mm cooling fan increases airflow while minimising noise for a superbly quiet computing environment. The energy efficient Green IC circuitry consumes much less standby power (less than 1W) compared to other PSUs without this feature. The GS PSUs also meet ErP Lot 6 2010 Standby Power, WEEE and RoHS Standards. The latest PSU design standard is incorporated for compatibility with a wide range of CPUs, motherboards, and graphic cards. Two independent +12V outputs for core components facilitate highly stable operation.
- Two Forward Switching design
- Less than 1W standby power
- Meets ErP Lot 6, standby power and efficiency standards
- Ultra-quiet 120mm fan
- Efficiency: 84% Maximum @230VAC, Typical load
- +3.3V max load: 22 A
- +5V max load: 18 A
- +12V1 max load: 21 A
- +12V2 max load: 18 A
- -12V max load: 0.3A
- +5VSB maximum standby current: 2.5 A
- Fan: 120mm non-LED
- Number of Molex connectors: 4
- Number of floppy drive connectors: 1
- Dimensions: 140(L) x 150(W) x 86(H) mm
- ATX12V (4+4-pin) support: Yes
- 20+4-pin ATX connector: Yes
- PCI-E support: One 6-pin and one 6+2-pin
-Mains input voltage: 230 VAC, 50-60 Hz
- Fan speed control: Thermal
-Safety Features: OVP, SCP, UVP, OTP
- EMC, safety approvals: CE, CB, RU, MIC
- Length of 20+4-pin ATX Connector: 500mm
Was [£32.99] Inc. VAT
Only £28.99 inc VAT.
ORDER NOW
Great savings on PSU guys THIS WEEKEND ONLY!! :)
Any chance of adding some others? Seasonic Fanless maybe? :-( Really nice prices on stuff today, just not stuff on my wish list.
OK this is the best we can do:-
Seasonic 400w FANLESS '80 Plus Platinum' Modular Power Supply @ £89.99 inc VAT
The Platinum Series, certified in accordance to the 80PLUS highest standards, offers the newest technology and innovation for performance and energy savings with up to 92% efficiency and a true power factor of greater than 0.9PF.
- 80PLUS® Platinum Certified Super High Efficiency
- Full Modular Cabling Design
- Fanless- 0dBA
- Patented DC Connector Module with Integrated VRM [Voltage Regulator Module]
- Highly Reliable 105°C Japanese Aluminum Electrolytic Capacitors
- Tight Voltage Regulation [±2%]
- Active Power Factor Correction [99% PF Typical]
- High +12V Output
- Gold Plated High Current Terminals
- Dual Sided PCB Layout
- Ultra Ventilation [Honeycomb Structure]
- Multi-GPU Technology Support
- All-in-One DC Cabling Design
- Easy Swap Connector
- Universal AC Input [Full Range]
- 7 Years Warranty
- 33A (396W on the +12V Rail)
Connectors
- Motherboard 24 Pin x 1
- CPU 8/4 Pin x 1
- PCI-E 8-6 Pin x 1
- Molex 4 Pin x 5
- SATA x 6
- Floppy x 1
ORDER NOW
Seasonic 460w FANLESS '80 Plus Platinum' Modular Power Supply @ £99.95 inc VAT
- Fanless- 0dBA
- High +12V Output
- 7 Years Warranty
- 38A (456W on the +12V Rail)
Connectors
- CPU 8/4 Pin x 1
- PCI-E 8-6 Pin x 2
- Molex 4 Pin x 5
- SATA x 6
- Floppy x 1
Was [£113.99] Inc. VAT
ORDER NOW
Seasonic 520w FANLESS '80 Plus Platinum' Modular Power Supply @ £109.99 inc VAT
- Fanless- 0dBA
- High +12V Output
- 7 Years Warranty
- 43A (516W on the +12V Rail)
Connectors
- CPU 8/4 Pin x 1
- PCI-E 8-6 Pin x 2
- Molex 4 Pin x 5
- SATA x 6
- Floppy x 1
Was [£129.95] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Ordering the 400w right now. Cheers :-)
Building a new HTPC so silence is key.
EDIT: will order as soon as I am not on a filtered connection. . . . !
Right that's a new rm850 ordered. Been wanting to replace an old generic psu I've had for ages and always felt nervous about if it went pop.
Or the Corsair 850 gold..
Both cost a ton, which one would be better for a single card?
Get the Corsair. Both 80+ Gold both 5 years warranty but the Corsair is 850W and fully modular + fan doesn't run until after 40% load.
Both are going to run it single card great. Seasonic has a reputation of being second to none but Corsair Also make quality psu check who give better warrenty If both same then i would favour the 850 more room to expand
My RM850 arrived this morning (24 hours for delivery?! Outstanding!) But the power cable only has a European plug connector not a UK one..? Is this normal?
Thanks for letting me know, mines arriving monday, would hate to find I can't set it up because I'm missing a plug.
Are Ocuk aware of this?
