- 24 Sep 2013
- Exmouth, Devon
Runs silky smooth on those. Was just hoping for extra performance from your non throttle at the top. Maybe I need to check your BIOS's in pos 1 installed correctly and check what's in BIOS 1.
One thing I do get moving the switch then rebooting is a 'light' blue screen with a sad face saying it has encountered a fatal error. Must be part of the POST. After a few seconds it reboots itself and pick the card up properly.
I also have had problems installing the drivers. SCreen stays blank for 10 mins requiring hard reset. I now cannot untick gaming evolved. Used sweeper and fusion but to no avail. Wish ATIman uninstaller worked under 8.1. You cant use AMD uninstall itil as it ruins windows.
A thought - I saw in another post about problems with PCI-e Gen 3. Is your BIOS written solely for Gen 3.0 or is that an option when fettling BIOS's.
Cheers
Woodsta
Cheers
Woodsta
