HOLY GIANT PICTURES BATMAN - I thought I had suddenly lost 20 diopters from my vision!
Fixed
Fixed![]()
imo
compared to a single spring then very little improvement
compared to both springs then they require less force to activate the switch.
they also do not fire when the locking ring is unlocked and you have a heavy atty full of juice ontop.
@Jaffa_Far - Posted the magnets in a standard envelope, first class. However, after reading the Royal Mail prohibited goods list they are allowed IF packaged properly in 2cm packaging and a field strength that does not go over a certain threshold, so they may get pulled by Royal Mail as they are quite strong.![]()
7-10ml a day of 12-18mg liquids?![]()
NirK, it's very hard to overdose on nicotine while vaping, I've gone through phases of chain vaping plenty of times. Do you have an addictive personality? 7-10ml is a LOT of liquid. 1.5-3ml is my range per day these days
e: Ordered a whole bunch of Joose Juice samplers, have been impressed with their juices so far for the price. I like the customisation options (nic, PG/VG ratio). They even let you tailor samples
I usually have an all day vape, like coffee or coconut, and mix it up in the evening with a brandy or citrus juice on my dripper
Vapours tounge usually refers to you becoming "immune" to a flavour if you vape it for too long. Changing flavour for a bit sorts thatI usually have an all day vape, like coffee or coconut, and mix it up in the evening with a brandy or citrus juice on my dripper
Yas, thanks for the liquid, tried it earlier and it's quite pleasant so thanks very much![]()
I could not taste much of anything, even the food I was eating tasted bad.... I think what we can learn from this is that vaping is good in moderation, but quite unpleasant if you do it too much!
Got my order of Five Pawns Gambit today and it's fantastic stuff. Bit pricey at 23 quid mind.
even if you go through group buys.
@nirk getting through that quantity of juice in that mg is a lot.
I was on about 5-10 GV rollies a day and I get through about 1-3ml liquid of 9mg strength a day now.
If you want to try lots of flavours and get through that much liquid in a day then go for a much lower nicotine level like 6mg or something or buy a dipper so you can try different flavours small bits at a time!
@Jaffa_Far - If they get confiscated by RM then there is no need to cover any loss. The problem isn't screening, but the field strength of the magnets which will stick to anything metal. I held a spoon next to the envelope from a cm away and it managed to attach to the envelope lol
Chances are the batteries are knackered by now after sitting charged for so long. If the atty doesn't heat up at all then it's either that or the coils are buggered. Either way, that kit is a bit of a dead end with that fitting. the 910 connector is a bit like the laserdisc in that it was in a battle for becoming the "standard" against the 510 fitting, which won.
