Hp touchpad flashing to android?
Can't type for toffee
Don
14 Jun 2004
Newcastle U/T
Hey guys,
Been outta the loop on these tablets for absolutely ages.
The missus has pretty much stopped using her touchpad so it's time for me to adopt it :p
Wanting to put android on here, was there a step by step guide or anything?
Pretty foolproof?
also anyone running one with android whats currently the best ROM option?
Just did two of these, all the guides are out of date. Follow this one > Link
Substitute for the latest files, see the screen shot below. Though they may not be so easy to find, took some effort to find as I remember. Included there is the web doctor version that can reformat the memory if it all goes wrong.
Much appreciated dude :)
DLing now
EDIT: Which walkthru/guide did you use with those files?
Does BT work on these yet?
DLing now
None of them, I've done it many times. But the link I provided looks the nearest, barring the older files used. And the firmware I uploaded was an experimental build with BT that worked and was stable.
Just got round to doing this now lol...
Got tux and a loada code scrolling on the screen atm, will let u know if everythign goes wrong :p
Installed :D
Cant boot into Android tho, get the CM logo then the HP logo and back to moboot :(
Appears I can boot into WebOS tho
gonna try that now, just copying everything offa the touchpad before I go any further, shoudla done it first like :p
And thanks for replying dude :)
Yup got a loada options now after the CM logo
