The F1 2014 season
...though to be fair they do have to run types so I guess you're right but my point stands, it's still forcing the point. Tyres have been used to create a 'show' and I dislike that, I hate fuel restrictions even more.
The 2 compound rule brought in when Bridgestone became sole supplier was specifically designed to ensure drivers made at least 1 pit stop. At that time a lot of races could have been easily completed without stopping.
Fuel restrictions won't be a problem. They will easily be able to run a race with less than 100kg of fuel. It was a restriction imposed to ensure the engine manufacturers made efficient engines, and they have done.
There is a progressive freeze in place from 2015. As well as a reduction in the number of engines to 4.
2015
Upper/lower crankcase: Cylinder bore spacing, deck height, bank stagger.
Crankshaft: Crank throw, main bearing journal diameter, rod bearing journal diameter.
Air valve system: Including compressor, air pressure regulation devices.
2016
Upper/lower crankcase: All dimensions including cylinder bore position relative to legality volume, water core.
Valve drive – camshafts: From camshaft lobe to gear train. Geometry except lift profile. Includes damping systems linked to camshaft. Exhaust and Inlet.
Valve drive: Position and geometry. Gear train down to crankshaft gear included, and dampers.
Covers: Covers closing the areas in contact with engine oil cam covers, cam-timing covers.
Ancilliaries drive: From ancillary to power source. Includes position of the ancillaries as far as drive is concerned.
2018
Valves axis position: Includes angle but excludes axial displacement.
Valves drive: From valve to camshaft lobe. Position and geometry. Exhaust and inlet. Includes valve return function inside the head.
Crankshaft: Except crank throw, main bearing journal diameter, rod bearing journal diameter. Includes crankshaft bearings.
Oil pressure pumps: Including filter but excluding internal if no impact on body.
Oil scavenge systems: Any scavenging system.
2019
Cylinder head: Except modifications linked to subsequent modifications.
Combustion: All parts of parts defining combustion including ports, piston crown, combustion chamber, valves geometry, timing, lift, injector nozzle, coils, spark plug but excluding valves position.
Con rods: Including small and big end bearings.
Pistons: Including bearings and pin. Excluding crown.
Oil recuperation: Oil/air separator, oil tank, catch tank.
Engine water pumps: Include power unit mounted water pipes.
Injection systems: Power unit-mounted fuel system components e.g. high pressure fuel hose, fuel rail, fuel injectors, accumulators but excluding injector nozzle.
Inlet system: Plenum and associated actuators. Excluding pressure charging, trumpets and throttle associated parts and actuators. Trumpets and associated parts and actuators. Throttles and associated parts and actuators.
Pressure charging: From compressor inlet to compressor outlet. From turbine inlet to turbine outlet. External actuators linked to pressure charging.
Ignition system: Ignition coils, driver box.
Lubrication: All parts in which circulates oil under pressure (oil pump gears, channels, piping, jets) and not mentioned elsewhere in the table.
Friction coatings
Sliding or rotating seals
Complete Motor Generator Units for Heat and Kinetic energy – all internals including bearings, casing, etc…, their position, transmission and power electronics.
Energy Store: Cells.
Energy Recovery System – Cooling/lubrication: Including energy store jackets, pipes, pumps, actuators.
I'd hope that 2020ish saw a new set of regulations for engines. The V8s lasted 8 years, 2020 would be 7 years of V6s.
Goodness me, how a thread can descend...
Anyway, I thought I'd just drop in to say that I've bought my first 2014 F1 tickets - Barcelona, in stand F.
Looking forward to it.
Gary Anderson has done a pretty decent analysis of the new regs on the BBC site. I like the preset engine mappings for the turbo - it means Vettel won't be able to ignore Rocky when he says "knock it the hell off and just win", or he'll run out of fuel.
That's not a good thing. It just means fuel conservation all round -> nobody pushing.
Yeah I hope Perez gets a seat at FI.
Please no more Di Resta and bye bye Chilton at Marussia and I will be very happy.
Could do with Sutil getting a drive somewhere tbh. Purely for his QT in the pits.
Aside from engine maps, you can conserve fuel by coasting just before braking zones (and some drivers are quite adept at doing this while still maintaining a relatively quick pace). With tyre conservation you're slow through the corners which affects lap times much more.
Is the fuel tank size being reduced?
2014 - The shape of things to come
Image is large
Yes, well the fuel limit is. They are limited to 100kg of fuel for the race, and a maximum fuel flow rate of 100kg per hour.
However, early signs are that this will be easily met by the new engines as they are far more efficient than the V8s. Mumblings in the paddock suggest pretty much all races (so basically everywhere other than Monza and maybe Spa) can be run flat out all race within the fuel limit. So as before, there will be fuel saving because the teams want to run the cars as light as possible, rather than because they would actually run out.
That's good news I suppose, that it can be run flat out and the teams aren't forced to fuel save (though as you say, they likely will to under fuel).
