Welcome to the team Kobi!![]()
whats the highest clock people have achieved on the ASUS M5A99FX ? as i currently have that motherboard - and this is stable wise?
Also what is a better overclocker the sabertooth or crosshair v formula?
ps i mean this with the 8350
Asked this in the mining thread but it got buried with a flurry of other stuff. Been doing some litecoin mining on the rig and due to a glitch in the mining software I saw GPU1 temps rise to 99C but GPU 2 stayed at 70C. All fine on reset. Is there a setting in AB or software that can shut off a GPU following a set temp threshold that you set manually. I know cards are supposed to throttle but just wondering if there is another way.
"temp-target" : "70,70",
"temp-overheat" : "85,85",
"temp-cutoff" : "95,95",
Hey guys, just looking at the temps. I gave it a wee OC to 4.4ghz. Now i'm not 100% sure on this, but if the Heatsink wasn't on properly would the temp be high even when it wasn't under load? Reason I ask is, not under load its about(package) 13c(min) - 28c(max), and I've just been gaming for a couple of hours. Yet under Prime95, it hit 51 and was still going higher. Now dropped to 11c min and hangs about 12c. Think its not on properly or is it fine?
Yep I'd agree with Andy. Prime is a big time waster in my view. I dislike any "stress testing" software to be honest but LinX is fast and in around 5 passes you get an idea of overall stability. After that, just use your system for normal things - bench, game, films, work etc. If it crashes/locks up, it isn't stable. Bump up the volts slightly/tweak memory settings and adjust Digi+ further to stabilise.
