Damn that e place
Will give it a day or two to see if anywhere else offers them with the cashback.
My current self build server is having abit of a nightmare with plex timing out, done everything I can think of doing but I think its time for an upgrade
Anyone know if an HP NC365T nic will work in a 1st gen Microserver?
What 3TB drives are you guys running? I have 4 x 2TB Samsung F4s at the moment but want to upgrade them. Seem to have come back down in price now from what I can remember
Would WD greens be better in this rather than reds, I'm just wondering as I want to run it as a NAS but wasn't sure which drives to buy?
Also I have 4Gb of 1600mhz ram spare from my desktop upgrade, would this work or would I be better just buying 8Gb of the 1333mhz stuff?
"A few"? =) That's quite a few!!However the same rep was taking my eyes out on prices for the G8 Microservers.... quoted me nearly £143k for a few loaded G8s, whereas another supplier using the same HP smartquote system came in at £110k.... I wonder which one will get the business?!
Has anyone had any luck getting Windows 2012 server R2 installed on a N40L? I've read online that there are compatibility issues with the onboard NIC (after I tried to do an upgrade, luckily the rollback worked).
God i wish i'd read that the other day!
I spent about 3hrs on Tuesday night, and around 4hrs on Wednesday afternoon trying to get it to work.
It'll install with the NIC disabled, but you cant go through the 3rd phase of installation because it cant connect to a network.
It cant install with the NIC enabled, it just freezes at 76% in the 2nd phase of installation
It cant install with the NIC disabled and getting to the 3rd phase, rebooting and enabling the NIC, because it either doesnt load the OS or if it does, it locks up inside there.
The best i've managed so far is to get into the OS, into network devices and right click the NIC and no sooner had i started moving to 'enable' it and it locked up.
I've been contemplating getting either a new G7 (mine is N40 iirc, first batch anyway) or possibly G8 but i think instead i'll put my old Q6600 back in use, just buy a case and PSU and use that as my server, the old microserver as a media player and i've got additional HDD storage if needed.
That's great news! Now I need to find the "good" hacked version.HP released a new BIOS dated October 2013 that fixes the onboard NIC issue. I have been successfully running it in a N36L with Windows 8.1 Pro and a N40L with Windows Server 2012 R2 for nearly two weeks now.
This BIOS does not contain the hack to allow the ODD and eSata to run at full speed, but unless you really need them (eg SSD in ODD), then it works fine
