- 15 May 2012
- Louth, lincs
Hi bud just wanted your thoughts on this, what would you do next?? keep pushing the bclk??
ram is tweaked as far as it will go without more volts unless you can recommend/or tell me otherwise
vcore in bios 1.41v with medium llc
ram 1.75v
sa 1.25v
vtt 1.2v
pll 1.65v
Have tested for stabillity and all is well, also just ran IBT(dont normally just used it to show you temps, was set to extreme)
thanks
ram 1.75v
sa 1.25v
vtt 1.2v
pll 1.65v
thanks
