Are you a Psychopath?
30%
You are warm and empathic with a heightened awareness of social responsibility and a strong sense of conscience. You like to carefully weigh up the pros and cons of a situation before you act and are generally averse to taking risks. You are very much a ‘people person’ and dislike conflict. ‘Do unto others…’ are your watchwords. But, although you avoid hurting others, those residing at the higher end of the psychopathic spectrum might not be as considerate, so stay vigilant to avoid being hurt unnecessarily.
Though your conscience is in the right place you also have a pragmatic streak and generally aren’t afraid to do your own dirty work! You’re no shrinking violet - but no daredevil either. You generally have little trouble seeing things from another person’s perspective but, at the same time, are no pushover. ‘Everything in moderation – including moderation’ might sum up your approach to life.
64%
**** me that's spot on. :eek:
Your
score 91%
You can play hardball with the best of them! You know what you want and are not afraid to go for it – even if it means bending the rules occasionally and putting a few noses out of joint on the way. Nothing fazes you. You are decisive, self-confident and pretty much up for anything. You are a ‘means-to-an-end’ person. For you, it’s not necessarily a matter of right or wrong, but of what gets the job done. ‘Bring it on’ is your mantra, but to help those around you keep their heads, you should learn some tricks to help you temper your self-satisfying tendencies...
Oops!
It looks like I'm joining the club
YOUR
SCORE 39%
I've worked with a sociopath/psychopath for roughly 6 months. It wasn't one of those stereotypical highly intelligent violent type but all the typical characteristics were there: high charisma, no guilt or remose, deception, incapacity to mantain relationships etc.
He showed complete lack of empathy but, interestingly, he adapted and learned to fake it. I suspected what he was after a couple of months of working with him and I tested my hypothesis when his father (with whom had he no conflicts) became terminally ill with cancer. He would put up a fake facial expression of sadness when discussing the subject but at the first slight change of topic, his face would light up instantly and go back to normal (as if he was relieved after making an effort) . Any mention of the father would be accompanied by the activation of the "mask" followed by it being easily discarded soon after. His father's suffering had absolutely no emotional impact on him.
I'm pretty sure he wasn't aware of what he was and that he didn't "plan" to adapt to live as a normal person in society, it was more of a subconscious trial-and-error self-teaching. Fascinating creatures, these people.
YOUR
SCORE 85%
You can play hardball with the best of them! You know what you want and are not afraid to go for it – even if it means bending the rules occasionally and putting a few noses out of joint on the way. Nothing fazes you. You are decisive, self-confident and pretty much up for anything. You are a ‘means-to-an-end’ person. For you, it’s not necessarily a matter of right or wrong, but of what gets the job done. ‘Bring it on’ is your mantra, but to help those around you keep their heads, you should learn some tricks to help you temper your self-satisfying tendencies...:eek:
Bahh humbug and i said i like fluffy little kittens:confused:
Wow, 21%. Feel like a bit of a pushover!
"You are warm and empathic with a heightened awareness of social responsibility and a strong sense of conscience. You like to carefully weigh up the pros and cons of a situation before you act and are generally averse to taking risks. You are very much a ‘people person’ and dislike conflict. ‘Do unto others…’ are your watchwords. But, although you avoid hurting others, those residing at the higher end of the psychopathic spectrum might not be as considerate, so stay vigilant to avoid being hurt unnecessarily."
Sounds about right.
79%
YOUR
SCORE 79%
Gulp.
79%
That's what I got as well, doesn't mean we're Psychopaths, just that we're ****'s.
YOUR
SCORE 39%
It rubs the lotion on it's skin or it gets the hose again
YOUR
SCORE 100%
