Delete the thread Burnsy, it's not based on any reliable sources
if we used that as a general rule of thumb, there wouldn't be many threads left on these forums.
But you just precisely proved my point. If you actually think that's funny it's probably a good and very healthy thing
It says the [Metro] "Start Screen" replaces the start menu.
Therefore:
Metro Start Screen ≠ Start Menu.
Metro ≠ Start Screen
Metro ≠ Start menu
Do you realise what the word Metro defines? Thinking that "Metro" is the start menu is like saying a Samsung Microwave is a TV.
Just because a Start Screen is merely present in the Metro system does NOT mean Metro is a Start Screen.
But there's still no need for it to take over the entire screen. The whole thing has been unintuitive since the start.
You cannot navigate a program while navigating the start menu (same with typing) so simply having a menu pop up that occupies the screen, it has the same attention grab as a menu that pops up in the corner...
People tend to say things like "it's unintuitive" when they just mean they don't like it for what ever reason.
It's not unintuitive just because you don't like it, I'd say it's quite intuitive in that it's basic, visually apparent in what you do and what your options are, and if you want to be as quick as you can you just press the start button on your keyboard and type.
I don't think you can really get any more intuitive than that, or quick.
1+Wat
Also it's not called "metro", it's just the start screen, and it is a start menu in that it does the same thing as the start menu just in a different visual format.
Your logic is really bad here, because you're basically saying it's not a start menu because it doesn't look like the classic start menu.
There's been multiple versions of the classic start menu for one, which one counts as the "true" start menu? It can only be one according to the way you're talking about it.
I really don't get the crying people are doing over it. It's quicker than ever to access apps and so on in Windows 8, and if you want to be as quick as possible you press the start button (on the keyboard) and start typing the first few letters of the app you want to launch.
why..
what's to says what is a true start menu.
just because the new start menu takes the entire screen doesn't make it any less of a start menu.
Customers vote with their wallets, Windows 8/8.1 has flopped.
It's only a minority that are happy with it added to those profiting from start menu hacks.
If Microsoft want to get rid of the Start Menu and reinvent a brand new operating system for keyboard and mouse users then great, I'm all for it.
What I don't want is to be given half of Windows 7, half of Windows Phone 7 OS and told "live with it".
I'll drop the Start Menu right now if you show me an interface that improves on it.
Windows 7 was widely considered to be perfect
