- 15 May 2012
- Louth, lincs
Thought they were taking the vrm things off die and back to the motherboard, or would that require a new board??
4820K is a great overclocker.(I run mine at 5Ghz 24/7 without trouble).
Also 4820K has broken quite a few overclocking records.
4930K though, isn't, due to the fact that is 50% bigger, generating more heat and power. However most can get to 4600 without trouble.
And 4960X is just "eXotic".
I'll be sticking with my 3770K. Nothing else interests me at the moment and i don't think there's any other CPU that would make a worthwhile upgrade either.
Just get the 4770k now tbh.
Depends what you are currently running though. If you are running a 2500K with a decent OC on it going to a 4770K is in my eyes a pointless upgrade for the money you would have to shell out for a new mobo + CPU and likely RAM unless you are already sitting on some 2133 or higher, or if you have some very good clocking 1600.
In real terms if you went from a 2500K @ 4.8 to a 4770K how much performance increase would you see other than in synthetic benchmarks ?
Still stuck on my 2600k, nothing interests me at the moment.
Haswell -E is where things become more exciting, more cores, lower power use and DDR4, a worthy upgrade from the 2600K.
True but at the start DDR4 is going to be stupid expensive if the launch of the other variations is anything to go by.
Sounds like my sexy old i5 750 4GHZ will remain for many years to come!
