If your running Win 8 or 8.1 is a little tricky, it will start in a little box top left, click on it and then Alt + Return Twice to get it to normal full screen, do it as fast as you can. before the credits are over and the bench starts.
clearly you and Kaap must be wrong
AMD has 512-bit which is just better, just like my amp goes to 11 making it one louder than whatever you have
I don't think it will be long before AMD or NVidia do it if they are serious about 4K.
If it's not too dumb a question... how can you tell what type of memory is being used on your gpu? Eplida, Hynix, or Samsung. Will Gpuz show this?
There is a tool called HawaiiInfo.
I can't find it anywhere except OCN which requires reg, so I put it here:
http://www53.zippyshare.com/v/38595604/file.html
Also included is a less-useful program called MemoryInfo which doesn't work with multi-GPU.
 will download when I get home
 will download when I get homeIts actually more to do with what speed the Memory can do, on the 290/X the memory IC's are rated for 1500Mhz, they don't usually go much over that unless you over-volt them, espesialy if they are Elpida. clock them to much past 1500Mhz and the performance gain falls off a cliff.
	It is better and that shows itself at multi-monitor resolutions and 4k. It would seem from Kaap's testing it is not a big advantage at 1600p over the 384 bit bus. The r9 290x was marketed as a 4k card which is where amd must feel the 512 bit bus has it's biggest advantage. Nvidia must see it this way as well as with the 780ti they added faster memory to give it more bandwidth over the r9 290x.
thing is, at 4K resolution you are talking about needing 3-4 cards of the current gen to get decent playable frame rates... in multi card setups each card has it's own discrete 384 or 512-bit bus, there are some textures and data that need to be shared but if you have plenty of VRAM available then this is minimised, so the memory bandwidth requirements for each card actually go down, not up when you go from single card 1440 to 3 card 4K
780ti's have a big chunk less bandwidth than a 290X out of the box (about 10% less at stock settings) but it doesn't seem to affect frame rates looking at 3 way 4K comparisons - BF4 is the only game that currently comes close to "favouring" the 290X and that is hardly surprising
most Titans and 780's will easily do 7000 on the memory in any case
a single card at 1440 is being pushed quite hard, as can be seen by the sub-30fps minimums and sub-50 averages, and yet in these conditions that memory bandwidth alone is making single digit or even fractions of an fps differences
No a gtx780ti comes out of the box with 336 gb/s memory bandwidth compared to 320 gb/s on the r9 290x. You don't need more than a single card to play at 4k as has been shown but you need to compromise setting's. I don't think it works the way you are saying anyhow as at multi-monitor resolutions 7970's were stomping gtx680's even in sli and tri-fire and it was all down to the memory bus at the time.
sorry, I'd miscalculated the stock 290x as 6000 instead of 5
7970's with later drivers were stomping 680's because they were much bigger GPU's, they should have always done so but the early drivers weren't up to much
Even with the 780ti having more memory bandwidth out of the box the r9 290x is almost equal to the 780 ti at 4k where as at resolutions below this the ti is clearly faster. The only thing that could be helping the r9 290x is the wider memory bus.
4K = huge pixel mass.
Pixel Fill Rate:
780Ti = 43.9
290X = 64.0
