I'm not sure that's true. I do tend to buy on release day, but as I say, it's easier to know which devices won't get much dev support.
i've rooted and flashed roms on every Android device i've owned, even rooted my Nokia WP7 phone and flashed a WP7.5 update just to get the latest.
But on this phone, it's good enough to not bother, i get 0 crashes no battery drain from kernels which are supposed to be better, and everything just works.
You can download the Odexed and Deoxed flashable zip files to flash in recovery on XDA. Thats how i have updated to 4.4.1 and then to 4.4.2.
Its effortless.
i'm going to stick to stock, with a nexus device i think it's stupid to apply custom ROM's which are usually buggy.
i done it all with the nexus 4 and it was a pita tbh, i liked some of the features of the custom rom but none of them were life changing.
stock does everything i need it to do well.
with budget phones though or branded devices i would use cyanogenmod or PA.
i tried that pacman rom out on the nexus 4 and it was buggy as hell.
I never had a single problem with CM and PA on the N4. The betas and nightlies can be buggy but the final releases are just as reliable as stock if you don't tinker too much with kernals. I think its a bit naive to say its "stupid" considering most of the developments from custom roms normally end up in some way sooner or later into stock android. In 4.4 some apps now run in "immersive mode" hiding the status and nav bar. This feature (Pie mode) has been available on PA for like ages.....
Stock android is very bare. Lacks basic things such as quick reply for SMS and a battery %...features which custom roms have had for a long time. Its custom devs which make android a pleasure to use.
What was so PITA? Download and flash. It's as simple as that. All you got to do is a nandroid copy before hand so if anything goes wrong you just restore it and your back up and running within 10min.....
see all those "features" you talk about, you do know they have apps now that do them?
i mean there is now a pie app, a holo app, a battery percentage app, etc, etc.
so i stick with stock as it is 100% stable unlike the custom ROM's and just install the app which enables the feature.
in fact for every feature a custom rom has which is good someone then turns it into an app sooner or later.
therefore no need to choose custom ROM's when you can can pick and choose which features you want through apps.
there's no need for a lot of things when you put it that way.
Who said we 'needed' it in the first place?
Did you need to upgrade to the N5 from the N4?
