- 12 Oct 2009
That's a lot of yellow snow! Someone had a very full bladderIt'll be fine. Just remember to leave the shovel and brush outside the car
Currently in Les Deux Alps myself as I type, temps at ground level are around 7 degrees. In a nut shell, you'll be fine....
Hows the snow in L2D? Going to ADH end of next week, webcams aren't looking great.
Guess I could just smell it??
Er, you could do but it won't tell you much
Ideally you should know whether or not the coolant is in good condition and in the right ratio of water/antifreeze. When was it last changed? Is it the blue type or the pink/orange type? Blue type should typically be changed every two years, or 5 years for the orange/pink stuff. If you can't even tell what type it is from looking at the header tank because it just looks like water then it's probably so old and diluted down it should be changed anyway.
Left my Firebird out in similar conditions and that was just fine![]()
