I keep getting it cut out if idling a long time,or when pulling away,then its hard to start
if I wait 10-20 seconds it will start,its deffo flooding,high speed its fine but just at idle,im hoping its a dodgy plug/plugs probably check the stand and clutch cut out switches but aint had time atm
only last three days its been doing it
 so put a ladies tights leg over it for now till I can get a new one
If running Iridium plugs on any bike, one thing to keep firmly in mind is to set the gap larger than that stated for the standard plugs that come with the bike. Iridium plugs have a much smaller electrode than a standard plug, so they will initiate a spark at a much lower voltage. Increasing the gap brings the required spark voltage back in line with that outputted from the coils. It also gives a longer a bigger spark than any standard plug would supply. This is then what gives better throttle response and smoother running. Those that just set the gap as stated in their bike manual are not using the full potential that swapping to Iridium plugs should give them.
The recommended gap for Denso Iridium plugs in my Ducati 1098s is 0.035 inch, in fact running them at 0.04 inch is much better all round than the standard gap.
