Skeeter made the op but doesn't update![]()
I dont spam updates because if people want to look for a update then the link to the place to find them is in the first post.
It would be nice if you kept it updated or just ask a Mod to pass over the thread rights to neil.me neither
- hardware device manager > right click gpu > uninstall
- shut down pc
- new gpu in
- boot up
- reboot
- update drivers
- done.
I'm switching to a fresh install of Windows 8.1 Pro anyway, so I thought I would try this for the very first time, removed Nvidia Drivers through safe mode. I'm using Intel HD graphics at the moment.Avenged7Fold said:Nice find. Do you still need to go through the registry to make sure things are gone?
Download latest version 9.9 (12-10-2013)
Changelog:
-Just like AMD, DDU will Not stop on little errors for the NVIDIA cleanup anymore when it finds error, it will try to continue if possible.
-Changed the way I change registry permission for the removal of some protected key.Thanks to Helge Klein for the authorisation to use SetACL.exe with DDU
-Re-enabled the LEGACY_AMDKMDAG Cleanup (WORK ONLY IN SAFE-MODE) .
http://www.wagnardmobile.com/DDU/
Release 9.9.1
Fixed a huge bug affecting a few users that could have corrupted the registry... preventing some windows features to work correctly.
Release 9.9.2
-Fixed a small possible crash that could happen near the end of the CleanUP.
Release V10.0 (Happy new year to all DDU users ! )
Changelog:
-Added preliminary support to Intel display driver. (currently only remove the driver and clean the driver store, no file removal or registry cleanUP)
-DDU can now restart the computer into safe mode by asking the user if he wish to. (WinVista+)
-Speed up DDU reg cleanup compared to 9.9.2 (A lot on some systems)
-Fixed a bug on the auto-notification of update that would have prevent it to work on version 10+
-Updated DDUDR to add support to Windows XP 64
-More than 100+ new registry key for Nvidia are cleaned.
-DDU should now start automatically after rebooting into safe-mode by DDU.
-Enhancement to the About box(automatic resize)
-Polish language update (Thanks to sirDaniel)
-Dutch language update (Thanks to Elite3540)
-Many little fixes here and there on the code.
10.1(01-07-2014)
Changelog:
-Changed the way GPU and driver version are detected and shown in the log to avoid some bug reported by users.
-Fixed a possible DDU crash when doing the Driver store cleanUP.
-Cleanup of display cpl from the pnpressource section. win8+
-Added cleanup of the HKLM\SYSTEM\CurrentControlSet\Control\Video section for NVIDIA.
-Quick workaround to correctly clean the driver entry of program and features of Dutch systems.
-Updated ddudr
-Russian Translation updated (Thanks to homocomputeris)
-Fixed aboutbox autoresize.
Release 10.2
-Changed how stuff get deleted on disk and some region of the registry.(Nvidia only)
-Fixed an issue that prevented cleaning various stuff in the registry.(AMD and NVIDIA)
Release 11.2
Changelog:
-DDU now have a new installer(a real one) and icon. (the installer also have offers, nothing is installed without users approval.)
-Partly rewrite of the Installer/Product, updagradecodes, features, components on the different registry regions. (Nvidia / AMD)
-Now when DDU restart into safemode, it is now using Safemode with Networking
-CleanUP of Some shellEx extension leftovers.
Changelog:
-Disabled DDU CleanUP if AMD Enduro Laptop is Detected until DDU correctly support its removal.
-Nvidia cleanup order reorganisation
-Workaround to not let the O.S rebooting infinitely into safemode when the normal procedure fail to set it back to normal.
-Some tiny leftover Nvidia removal
-New Language : Greek (Thanks to George T. Markakis)
About damn time![]()
