Only because people want faster cards they move up, it has nothing to do with insufficient vram in most cases
People reading this thread would think PC gamers all periodically switch to afterburner, adjust their spectacles, exclaim 'oooh, that's an interesting figure!' in a nasaly voice and record it on an excel document.
670 user here with only 2gb of memory, not had any problems with any games so far to do with vram @ 1920x1200.
Granted more is always better value with regards to memory, but by the time i get any vram issues i will have upgraded anyway, and can you imagine the increase in cost of an nvidia card with 4gb or 6gb vram
There are lots of factors to take into consideration in making a good / cool / quiet / fast / power efficient graphics card, and the amount of vram size makes no difference to me presently.
I ran out of VRAM frequently on Skyrim with my 770 2Gb. The game would crawl and stutter very frequently. Pauses of 0.5 sec or so. It was the reasoning behind me getting my first 780.
It's probably similar in other games, but it's difficult to break 3 at 1080p. Might have more of a problem when I get my 1440p monitor.
And they are now in a better place of having 3GB of vram without ANY worry on the possibility of running out of vram at 1920 res, leaving the people (who's likely to keep their card for 2 or more years) they "advised" to paid the extra £80-£100 to get the GTX670/GTX680 instead of the 7950/7970 behind and stucked with 2GB of vram, with risk of shuttering issue due to running out of vram despite having only bought the card for less just a year or less ago...Only because people want faster cards they move up, it has nothing to do with insufficient vram in most cases
Me too and I think SKYRIM has a well known bug @ over 3Gb IIRC, the game just crashes.
My take on NV's RAM rip-off has always been the same, whether it is required or not, cards costing £400-£500 should come with a minimum of 3GB, the 7950's at half that price all had 3GB.
I paid £184 for my card and it has as much RAM as cards costing more than double when I purchased it almost 2 years ago.
That's cannot be right.
Regardless of their reason for upgrading, it still doesn't change the fact they kept assuring others "the boat is not going to sink so soon" and yet they jumped onto a "lift raft" not long after saying that![]()
Show me a game that 2GB isn't enough for 1080P?![]()
But of course, he's either lying, or Skyim is a piece of poo nobody wants to play and so we might as well dismiss itI ran out of VRAM frequently on Skyrim with my 770 2Gb. The game would crawl and stutter very frequently. Pauses of 0.5 sec or so. It was the reasoning behind me getting my first 780.
See also this thread:
http://forums.overclockers.co.uk/showthread.php?t=18566422
Well the GTX 680 is 21 months old now and for the whole of its life and even now, I don't know a single game that 2GB isn't enough at full HD resolutions, so it seems that Nvidia were pretty spot on with putting 2GB on that card. They added a 4GB variant but with it still only being a 256bit bus, it showed how weak it was when going up against the 384bit bus at very high/triple screen resolutions.
[/b]
People have showed you many times, SKYRIM when heavily modded, you just refuse to accept it.
So I think people have stopped wasting their time, nothing will get you to criticize your beloved NV.
Needed or not, 2GB of VRAM on a £400-£500 card is a ripoff, and nothing you or anyone else can will say will change my opinion on that. So i'd suggest agreeing to disagree.
[/B]
.....How can you use Skyrim, if that's the case then 3GB isn't enough, 4GB...etc etc. Just keep adding mods...
You've been going on about 2GB isn't enough for yonks, yet you're still rocking the 7850 2GB version, woulda thought you'd have got the 4GB version![]()
The point I was making got drag off into a different direction........How can you use Skyrim, if that's the case then 3GB isn't enough, 4GB...etc etc. Just keep adding mods...
