Corsair seem to be resting on their laurels lately, used to be the go-to brand, shame.
The 1200 AX is not junk at all, it's a brilliant PSU. It's also a couple of years old now though, and it's underated if you want to overclock three 290Xs with an undisclosed TPD of 300w out of the box lol.
Then you've got the 1200i Digital, which is not made by Seasonic, and is the worst high end PSU I have ever used lol.
Agree with this, biggest mistake I made was selling my AX1200 and getting the AX1200i![]()
Ok nothing went bang, gpu-z reports 205w draw per card. Got a socket watt meter coming to confirm. But I think this system is drawing around 850watt.
Question, and Gibbo will know the answer to this. Is that leadex 1200w unit good enough for 4x 290's, and even 4x 290's overclocked? With my xeon 1660. How much faith do you have in this flower power psu's? I did read 8packs review and look great!
So my second question is when are you expecting more stock?
HI there
That Corsair unit could struggle.
The Superflower 1000W Platinum can do it with ease, even with CPU and cards overclocked, but it is Platinum rated.
You will simply have to try it and see, if you get stability issues, remove a card, if your then stable, swap cards, if still stable, then your PSU is struggling and time to upgrade it.
Be careful, there is a problem with these SuperFlowers.
http://forums.overclockers.co.uk/showthread.php?t=18569496
Corsair AX was good. AXi is not so!! All digital controller PSU by Corsair are sadly the same with a strange ticking noise and poor performance.
When I tested Superflower 1200w I had 4 x 290 all clocked and a Haswell at 6.2 for benching and it was all rock stable.
The Superflower 1200 is my current choice in PSU.
I have the super flower leadex gold 1000w psu. That will be fine for 2x290's oc'd I'm guessing but not for 3 right?
