lol, its slower than the Reference 290X. can that even be right?
Its a 290, not an X.
Im sure it goes a little something like this..
Dual X > Vapor X > Toxic (7xxx Series)
Tri X > Vapor X > Toxic (for the 290's at least)
I think the Toxic uses the Vapor X chamber with higher clocks and a better PCB
Only the die hard AMD fans will have waited for these and maybe bitcoin miners
They look great but they're a month too late.![]()
How do you work that out? Have you missed the 100's post by members all stating they are waiting for the quieter cooler running custom versions?
Most miners don't care about the cooler, they just want price point.
GTX780's dropping to around £350 on a few sites, some special offers and some are not. Would cost you more to buy R290 plus cooler so right now there's not much point waiting if your a gamer.
I also posted that I was waiting for non-reference version a while back but AMD took too long.![]()
Well I prefer to go from the real numbers which show 290 custom to be selling already faster than 290 reference was.
The 290 is faster than a GTX 780, the custom cards even more so as they come overclocked and once prices have settled custom 290's will sit in the 360-400 price range, same as 780. Yet 290 is faster, has better OC headroom potential, has a very high-end sound card onboard, is also handy for mining withand if Mantle kicks off then some big performance leaps still to come.
Edit ^^^ to late.
Thats dangerous talk on a GPU forum.
There is a review posted above that says otherwise, the non-reference versions of X290 and GTX780 perform about the same. Looks like GTX780 does a little better at 1080/1600p overall while the X290 does better at 4k.
GTX780's have a fair amount of headroom as well, 1200-1300 is easy.
Mantle is vaporware for now, I think the sales are largely due to mining.
Gibbo, is there a reason for the ETA mid jan, did I miss the first batch mate?
The Kitguru review posted in this very thread seems to suggest otherwise, have we read the same review? They say it trade blows with Lightning GTX 780, one of the fastest most overclockable GTX 780's ever released, it beats the Lightning or matches it in several test and beats the reference 780 in every game test.
To me the performance though close to the 780, the 290 does have the slight edge, I've had 780's clocked upto 1400MHz, but I've also had 290's clocked at 1225MHz so both cards clock well and both cards are very close, but the 290 does offer better value in my opinion. After all Lightnings and Classified's are still over £400.
Mantle vapour ware, only time will tell, I've seen what it can do, so if AMD can make it a reality then people will be impressed, if they can......
MSI GTX780 Lightning was at stock, it was not overclocked, it's clockspeeds are comparable to many other non-reference GTX780 which are cheaper so it's not special at all in that regard.
Those overclocks don't sound right for stock cooling, most GTX780 max out at 1200-1250, if you get to 1300 your lucky and even then probably not game stable. I'm going to presume your overclocking numbers for the R290 are just as unreliable.![]()
