The Machine will not boot Windows from USB stick. Update the front page
Fixed... I've booted several proper OS off of the internal USB stick, so it seems to only be Windows that has a problem (for a change )
Erm, mine boots Windows 2008 R2 off a USB all the time....
Formatting USB sticks for Windows boot can sometimes be an issue - it took me a long time to find a reliable USB formatting tool that worked - it's at home so I'll post a link later
Does anyone know how well unraid will work without the modded BIOS running from the internal SATA?
Many thanks
Here is the link to the German Forum where a hacked version was posted.
http://www.hardwareluxx.de/communit...n54l-microserver-752079-430.html#post21503128
If you're any good at German, you can read and decide for yourself whether you are ready to try it out.
Is it worth taking the 3 Year next day support out on this? Works out to be £50 after the cashback
Edit: Well I bought it today as I got a nice little bonus. For those who have ordered it from a retailer whos name starts with e, what invoice did you supply for the cashback?
Fair enough, did you buy from the same retailer I mentioned above? If so what did you do for the invoice?
