Opinions on £3k spec please
15 Dec 2013
Norton Canes
As soon as Christmas is out of the way I'm planning on purchasing a full rig and peripherals again. So far I've got this spec together, I'm going to have a couple of custom things done to the case hopefully and I'm trying to look to adding a second GPU and water clocking within 6 months.
Is there anything I should look to change on this spec? I love high end gaming and record footage too.
Your basket
EVGA GeForce GTX 780Ti Dual Classified ACX 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2888-KR) £639.95
Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74930K) £449.99
Asus Rampage IV Extreme Black Edition Intel X79 (Socket 2011) DDR3 Motherboard £429.95
Benq XL2720T 27" TRUE 120Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red £329.99
Samsung 500GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE500BW) £289.99
Kingston HyperX Beast 16GB (4x4GB) PC3-19200C11 2400MHz Quad Channel Kit (KHX24C11T3K4/16X) £161.99
Corsair RM Series RM 1000 '80+ Gold' 1000W Power Supply (CP-9020062-UK) £155.99
Logitech G710+ Mechanical Gaming Keyboard (920-005701) - Brown Switch £134.99
Parvum Systems S1.0 MicroATX Case - Black with White Parvum Systems S1.0 MicroATX Case - Black with White £129.95
Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £99.95
Samsung 120GB SSD 840 EVO SATA 6Gb/s Desktop Kit - (MZ-7TE120KW) £89.99
Logitech G700 Wireless Gaming Mouse (910-001759) £74.99
Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
Corsair Air Series AF120 1500RPM LED Red Quiet Edition - Dual Pack (CO-9050016-RLED) £16.99
Total : £3,129.08
Also, regarding the Parvum cases, I notice that you can have a dvd loading slot put in, but I've never really found I've needed one once the OS was installed. Any options so I can just not bother with a dvd drive?
Thanks in advance, I've browsed here a bit recently and it seems a great resource.
Ah ok, thanks for pointing that out, could have been a daft mistake!
Would you be able to recommend a case that will fit the MB? I would have liked the parvum but I'm prepared to have something else.
How about this ?
YOUR BASKET
2 x Gigabyte GeForce GTX 780Ti WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N78TOC-3GD) £559.99 (£1,119.98)
1 x Benq XL2720T 27" TRUE 120Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red £329.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £269.99
1 x Corsair AX860i Digital ATX '80 Plus Platinum' Modular Power Supply (CP-9020037-UK) £199.99
1 x Gigabyte Z87X-UD4H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £163.99
1 x Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) £160.00
2 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £149.99 (£299.98)
1 x Corsair Vengeance K70 Mechanical Gaming Keyboard - Black – Red Switch (CH-9000011-UK) £119.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £99.95
2 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (CMY8GX3M2A1600C9) £79.99 (£159.98)
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99
1 x Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - Red £64.99
1 x Corsair Vengeance M65 Laser Gaming Mouse - Black (CH-9000022-EU) £54.95
1 x BitFenix Alchemy Premium Modding LED Strip - Connect White 60cm £25.99
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £25.99
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
1 x Corsair AF120 Quiet Edition Low Noise High Airflow - Dual Pack (CO-9050002-WW) £19.99
1 x Corsair Generation 2 Sleeved 24 Pin Cable (AX) - Red £14.99
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
3 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Red £5.99 (£17.97)
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Red £4.99 (£9.98)
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Red £4.49
Total : £3,299.20 (includes shipping : £27.55).
The RAM in the spec is just a place holder as OcUK don't stock the kits I was after to complete it, This spec is themed (Red & Black as well as Corsair & Gigabyte) before you say "HOW MUCH" you may notice that for a small increase on your budget I have included 2x GTX 780Ti's for SLI action and 2x 256GB Samsung SSD's for some Raid 0.
The memory kits that your after are as follows:
Corsair Vengeance Pro Silver 2x4GB (8GB) DDR3-17100C9 2133MHz
Corsair Vengeance Pro Red 2x4GB (8GB) DDR3-17100C9 2133MHz
You can always drop OcUK a post in the customer service section on these forums to see if they will be getting them in again.
Yeah if I could have hid the PSU like you can in the Corsair 540 Air then I would have changed it but as your see the ugly cables coming out the PSU in this case I thought it best to use a PSU that has the red braid that goes straight into it :p. I know that I picked the AX***i as well but show me where OcUK stocks the old cable kits to match the theme ;)
£3k on a PC ???
My opinion is that is mental dude. No way is a PC worth that much.
The new mac pro perhaps but not a PC, besides in 12 months it will be lucky to be worth
half that.
why would spend 3k on a mbp be ok but spending 3k on a pc isnt? other than being an apple fan boi how exactly would you come to the conclusion that one lump of metal and silicon is ok but another is not? At least when buying kit from ocuk you get decent support rather than the usual tosh you get from apple
Because it's easier to justify paying massively over the amount for something if an apple logo is on it.
Apparently.
Why is not going 2011 a bit draft? For gaming 2011 will not bring you a massive performance increase over 1155/1150 by the time games can actually see and use more then 8 cores the chances are that a 2011 rig will be so old hat that it will need replacement.
Thanks for the replies lads, regarding getting a Mac and how much I'd like to spend. I don't really mind what it's worth in 6months time or whatever. Gaming is a big hobby of mine and I help run a gaming community, so I'm sure I'll get my monies worth :-)
I've already travelled the Mac route and I'll be letting them go once I have a PC built again. I never had to worry about a virus but for the money they cost they're not good vfm.
I appreciate the spec suggestions, I'll look into them in more detail this evening, in not sure about the 290x sli though, I have read on here they run hot, would that be an issue with only fan cooling? The same for having 780ti sli now too. I had presumed a move to water cooling when adding a second card would be needed to keep temps sensible for gaming.
Thanks again.
You will not have any problem with cooling with my spec as the cards will dump the heat into the case but with the 5 fans that I have spec'ed you will be fine with SLI, you could go watercooling but that will add more to the cost of the build.
£3k on a PC ???
half that.
LOL. :o
3k, why not go watercooled now?
YOUR BASKET
2 x OcUK Tech Labs H2O Custom R9 290X 4096MB GDDR5 Watercooled Graphics Card £499.99 (£999.98)
2 x EK Water Blocks EK-FC R9-290X £89.99
1 x BenQ XL2411T Rev2.0 24" TRUE 144Hz Flicker FREE 3D Vision 2.0 Widescreen LED Monitor - Black £281.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £149.99
1 x SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - Black £149.99
1 x NZXT H630 Silent Ultra Enthusiast Tower Case - White £129.95
1 x Gigabyte G1.Sniper Z87 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £112.99
1 x Avexir Venom Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CIG) - Green Light £79.99
2 x Hardware Labs Black ICE Radiator SR1 360 £69.98 (£139.96)
1 x Saitek Cyborg V7 Illuminated Gaming Keyboard £59.99
1 x XSPC X2O 750 Dual Bayres/Pump (Acrylic) V4 £59.98
1 x Corsair Vengeance M65 Laser Gaming Mouse - Green (CH-9000024-EU) £54.95
1 x EK Water Blocks EK-Supremacy Clean CSQ - Acetal + Nickel £52.99
2 x Monsoon 19/13mm (ID 1/2 OD 3/4) Free Center Compression Fitting Six Pack - Green £29.99 (£59.98)
3 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £25.99 (£77.97)
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
1 x Aqua ComputerTwinConnect 2-Slot - SLI/Crossfire Bridge £14.99
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - Green £8.99
4 x BitFenix 6+2-Pin PCIe Extension 45cm - sleeved green/black £5.99 (£23.96)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Green £5.99
2 x EK-EKoolants UV Green £5.99 (£11.98)
2 x Primochill Primoflex Advanced Tubing 19/13 - Clear £5.99 (£11.98)
Total : £3,071.57 (includes shipping : £27.55).
#1 - EDIT: Added the Multi-GPU block.
#2 - Go straight in the deep end! :D
That's great to know, as is the comments on reasons not to worry about 2011 socket just yet.
On the note of sounds, I already have a sennheiser 360D headset and use a blue snowball mic. I had a dedicated sound card before but it caused a terrible noise that was picked up when recording (like a very fast clicking) and it out me off a bit. Perhaps one with shielding would help in that respect? I tried my old rig with it as far from the gpu as possible but it made no difference.
I suppose the only reasons I didn't want to water cool now is because I've not learned quite enough about it just yet, and I wanted to spend as much as possible on a great spec then apply some learning to the water cooling to make the best job of it. I'm happy to listen to ideas on having a single gpu and water cooling now though. But if air will be fine for the build suggested above it's something I'll take more time over.
With the amount of heat the 780ti's will kick out, won't 2 reference models be wiser.
Why not 2 x 290X's and water cooling! ;)
Shhhhhh you ;) The GTX780Ti is still the quicker card in terms of a single GPU but that's just the limits of the stock cooler with the new cards with the custom coolers just being released that could be a game changer on air but water is a different kettle of fish .....
I have seen SLI GTX 780Ti's in a air cooled case with the same spec that I basically posted and the CPU temps at 4.7GHz were fine as were the GPU temps at around the 80c mark on the top card which is perfectly normal for an SLI configuration in a closed case at maxi chat on air.
The ref card could possibly cool a bit better but I think the effect on a system with be minimal. The ref card will dump heat generated dumped outside the case but it doesn't fit the theme that I was going for as well :D.
